In travel projects I often use the painting creator to markup up a map showing where events have been - a spot or line moving on the map showing location and route. I also recall a filter which did that sort of thing in a more detailed manner - eg, instead of a moving spot, a car icon travelling the roads.
For a new project I decided to be a bit more adventureous than normal and use that filter with car, train etc icons - but a search thru the filters doesn't show it. Cnnot remember the filter name, so I'd appreciate some advice as to which filter it is, or may have been.
Background markup with travel icons
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Background markup with travel icons
Rotopen.Davidk wrote:Cnnot remember the filter name, so I'd appreciate some advice as to which filter it is, or may have been.
tletter
- Davidk
- ram: 16Gb
That's the one.
Is there any way to import icons? I need a bus and a train, as well as those already there.
And it seems a bit touchy. I wound up clicking the icon button before closing the route sequence down and it seemed like it had frozen. Click in the map space freed it all up
Yes David - you can import your own icons and use whatever drawings you have - for best results your symbol needs to be on a transparent background or else you get the rest of it's background as well which doesn't look to professional - I have had success with transparent tif 's but I cannot get transparent png 's to work
After you have drawn your line then move to the "symbol" tab - in the top box under the words "import image" - click on that and browse to a Windows folder where you have stored your images
made this demo a couple of years back - it should help - https://www.youtube.com/watch?v=2JDhSa36vUI
just to test here is a transparent tif of a small train
