X9 Ultimate dropper tool and airbrush
caspia1
ram: 16gb
Hard_Drive_Capacity: 1Terrabit
Monitor/Display Make & Model: twin hp displays
Corel programs: Pro 2023 Ultimate
Post by caspia1 »
Must have changed a rule without realising, because when I select dropper tool and then airbrush, the colour/hue I selected is totally different when I apply the airbrush onto the image.
Can someone kindly explain what I´ve done wrong, please?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: X9 Ultimate dropper tool and airbrush
Post by Jean-Luc »
It is a bug.
You need to reset the tool :
caspia1
ram: 16gb
Post by caspia1 »
Tried this and it does not work either.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Double check to make sure you didn't change the blend mode. It should be set to Normal.
Click for larger view
If that's not the issue you could try resetting the workspace. Just be sure to save your workspace if you've made any customizations.
Here are the instructions if you need them. They reference X6 but the process is the same for all versions.
https://support.corel.com/hc/en-us/arti ... figuration
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Can you share a screenshot of your tool options palette so we can see your options?
Also, can you share a screenshot of your color palette.
Jean-Luc
Post by Jean-Luc »
caspia1 wrote:Tried this and it does not work either.
Insteed of Airbrush, could you test with PaintBrush (and reset the PaintBrush too) ?
EDIT : This is a random bug in PSP 2018 and resetting the tool corrects the defect. But you are on PSP X9 and there is no such bug in PSP X9. Are you sure you don't have some Texture or Pattern active ?
caspia1
ram: 16gb
Post by caspia1 »
I did some research and found that under "Materials," Foreground and Stroke was in shades of grey. So I changed that to Colour and this has done the trick, together with ensuring that under Tool Options Blend Mode was "Normal",which it was.
Problem solved with many thanks.
