Pan & Zoom
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
Pan & Zoom
Fix it. It crashes when in use. It should have never been released as is. Fails in Windows 10 and Windows 7
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: Pan & Zoom
You don't list the version of VS that you're using. In any event, I've used Pan&Zoom since X5 and it's not causing crashes and works in my experience. Pan&Zoom has a configuration issue in VS2018 but it's not related to crashing (see viewtopic.php?f=1&t=63601).pepegota wrote:Fix it. It crashes when in use. It should have never been released as is. Fails in Windows 10 and Windows 7
If you have an issue with Pan&Zoom causing crashing then you'd be better off contributing to the topic at viewtopic.php?f=1&t=63585 rather than starting a new thread.
tletter
canuck
Re: Pan & Zoom
Fix what? You give no details at al except make general complaint. If you want help be more specific.pepegota wrote:Fix it. It crashes when in use. It should have never been released as is. Fails in Windows 10 and Windows 7
FWIW, Pan & Zoom works without crashing when I use it in Windows 7.
pepegota
- ram: 64 GB
Re: Pan & Zoom
In animated mode when moving cross hair it may crash. VS 2018 latest rev. Since I can accomplish, through other means, what I want to do-no need for this aggravation.
tletter
Re: Pan & Zoom
I don't see this behaviour in VS2018.pepegota wrote:In animated mode when moving cross hair it may crash.
tletter
pepegota
- ram: 64 GB
Re: Pan & Zoom
All I can say is it happened on two computers.
tletter
Re: Pan & Zoom
Have a look at the topic at viewtopic.php?f=1&t=63585 and see if it applies to you.pepegota wrote:All I can say is it happened on two computers.
tletter
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Re: Pan & Zoom
I think what's happening is confusion between the FX filter Pan and Zoom item - been there a long time - and the newly introduced P&Z item in the timeline tool bar. there's also an old pan and zoom item available from the the options page for a selected photo image. The only new one is the 2018 P&Z inclusion in the timeline tool bar, and there's been quite a bit of discussion (separate threads in this forum) about it, not all happily.
So, pepegota, could you confirm which one is causing grief, and how?
Re: Pan & Zoom
The Pan & Zoom from the icon on the timeline tool bar and the options panel (double click the clip) are the same beast, at least they are supposed to be the same.
If you use the Icon, the options panel is also selected.
Try it!
Double click a clip to open options, click the Icon on tool bar, watch the options panel P&Z, becomes active.
The only way to remove the effect is from the Options panel by deselecting P&Z.
Yes it has been reported that these two seem a little different in their default views, so would be useful to know which is being selected, although i do not think it should be different.
There is another P&Z from the FX Filters, Video Pan & Zoom, now that is a different beast.
Pepegota
It is strange that you are having the same issues on two PC which could suggest a corrupt installation file.
Can you re-install the program
Please use the Cleanup tool from
viewtopic.php?f=1&t=59847
Delete the user folders as in info
Try it!
Pepegota
