Split by scene sensitivity
masterjaz_99
Post by masterjaz_99 »
Hello All,
Things would be great if I could have VideoStudio do one little thing. Here it is: I have a wonderful Home Theater PC set up that records all sorts of good shows. I would like to be able to quickly remove any commercials. This would be easy in that most commerical breaks are preceeded by a black or white screen (always 100%). So, if I could split the recorded video based on these black or white screens I could easily remove the commercials
Now the problem: VideoStudio 7 has a 'split by scene' function by even at 0 sensitivity, it still finds literally 100's of scene changes especially during action sequences and camera angle changes.
So does anyone have a work around or another piece of software that can perform this basic task? I am dying to get this working, as it would be the culmination of lots of hard work and tinkering.
Thanks in advance,
Masterjaz
THoff
Post by THoff »
I think the behavior of the slider is backwards, try setting the sensitivity to 100% or 99%.
masterjaz_99
Thanks for the hint THoff, but I believe I tested it at both extremes with no success. I'm going to try it one more time and then I'll update forum members.
THoff wrote:I think the behavior of the slider is backwards, try setting the sensitivity to 100% or 99%.
rjgeisler
Post by rjgeisler »
The slider seems to have very little affect on the sensitivity, but 0 is less sensitive and 100 is more sensitive. How it responds depends a great deal on the clip!
I would also like to see a black level scan method. To make it more efficient allow X-number of frames of black.
Rhonda
