Is it possible to convert an image into vector? If you can do it, can you explain step by step how to do it?
Michael
ORIGINAL MESSAGE
É possibile convertire una immagine in vettoriale? Se si può fare, potete spiegarmi passo passo come si fa?
Grazie
Michael
Convert an image into vector
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Convert an image into vector
If you mean transform a graphic (or a photo) automatically in vector, PSP cannot do it.-Michael- wrote:Is it possible to convert an image into vector? If you can do it, can you explain step by step how to do it?
Michael
Corel Draw has such possibility.
And I think you may find some softwares on the web...
Troy at TheGTAMblog
- motherboard: Gigabyte 970A-DS3P
- processor: Intel i3-8300
- Video Card: NVIDIA GTX 1060
- sound_card: Creative Labs Tactic Alpha 3D THX Certified
- Hard_Drive_Capacity: 11TB total
- Monitor/Display Make & Model: Dell 2407WFP
- Corel programs: PaintShopPro, VideoStudio
If I may pop in, you can 'pseudo-perform' such a thing manually, by utilizing the Pen Tool and tracing your image by hand on a Vector Layer. Creating Vector elements in this way, you can create a 'vectorized version' of an image, as complicated as you wish, adding multiple vector layers/elements, as far as you want to go.
However, as far as simple conversion or an automated process of converting a bitmap to a vector, J.L. is correct, there is no such automated process in PSPro at this time.
GL with it if you want to try it manually though - I have tried this in the past with my own logos and had pretty good success (so I wanted to add this here, to possibly help others), HTH
