Resize by KB
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Resize by KB
Post by MarkZ »
LeviFiction wrote:I don't know, that's still far too variable. JPG compression is based highly on the content and variation of the pixels in the image.
You're right - I had forgotten about that variation. I've seen differences in the size of images straight out of the camera by a factor of two or more when the camera settings were the same for all. Using one folder as an example, in 238 images the range is about 17 MB to 29 MB, a factor of 1.7. However, taking a sample from the middle, 210 images, 88% of the total, the size was 21.3 MB to 24.5 MB, a factor of 1.15. So it appears to be a fairly steep bell curve, most images in a small range of sizes with some outliers.
However, I expect if the images have been edited at different times, came from different cameras, had different compressions applied, the distribution may be a much flatter file size curve. Given that there is no way at the moment to go directly to file size, the OP would need to decide their tolerance on file size and consider bringing the oversized images to a common factor (long side pixels as an example) in a batch process and then decide on a next step.
Mark
okyou
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 2TB
Corel programs: X9 Ultimate
Re: Resize by KB
Post by okyou »
Wow, Thanks for all the help. Will try to use the script to test. Thanks again
