Before applying the upgrade I EXPORTED LIBRARY from my X10 so that it could be IMPORTED upon upgrade.
Did the upgrade which on FACE VALUE appeared to go OK. I did NOT deinstall X10 just in case I had the need to go back to it
Over about a week now I have started to see LOTS of problems that are driving me mad.
I am running on an Acer Quad Processor (screenshot attached) with 4GB RAM (small I know but this has never been a problem before)
My VS 2018 version is the very latest 21.2.0.113.
Once VS 2018 was installed I kicked off a new project (target 20-30mins final clip) - everything seemed OK and navigation changes soon understood.
Over some days, the following issues have STARTED happening - and most were NOT apparent when I started using VS 2018.
A) for some reason I am being prevented from altering any Project Settings (e.g. work file directory change) and I get the error
"Cannot write to the specified disc, Disc space may not be enough, disc may be write protected or the file or path name is too long"
- and I get THIS same message when whether I try to amend the GENERAL tab, the EDIT tab, indeed ANY of the tabs under preferences.
B) I can no longer select and MOVE clips withing the LIBRARY panel. Last week I could - this week I cannot. Once I upload clips into the clip Library, my general approach is to top and tail each clip BEFORE dropping the clip set to the timeline, and whilst doing this I often re-position the SEQUENCE of some clips for a better logical flow. Once this first pass is completed I usually then drop the set of clips to the timeline where I may perform further edits and FX etc. For sure last week with VS 2018 I had no probs doing this - this week it will NO LONGER let me select and shift clips around withing the Library ??
C) When I am happy with a project, I will always proceed to create an MP4 clip of the full set of clips, adorned with music, images etc. THIS WORKS OK and totally as expected. BUT when I subsequently try to use that MP4 to BURN a DVD, the burn process fails completely, so I cannot get a DVD out of VS 2018 as it stands at the moment. Starting as normal from the SHARE option, and selecting DVD from the next screen, USUALLY the next step drags the MP4 clip(s) into the DVD timeline - BUT it doesn't - the timeline is BLANK. After several abortive attempts trying to work out what might be happening, I tried to CHEAT my usual workflow by MANUALLY adding the MP4 into the timeline of the DVD burn step, but that doesn't work either and the process cannot be made to go to the next step where the DVD is usually then burned. SO I cannot get a DVD burned with VS 2018.
Be aware I generally have Smart Proxy set to ON for all projects - it seems to save both editing time and rendering time. (Except that I have been unable to amend proxy parameters because of the issue at A).
FINAL question - should I give up and go back to try to install VS 2018 AGAIN - and if so should I de-install VS 2018 before starting a fresh install. (I will of course do a Library Export before proceeding so as not to lose work) - and should VS X10 have been de-installed before VS 2018 was installed ?
ANY comments welcome - I was not expecting this to be such a trial and I feel as tho I have been found guilty of something somewhere
Cheers - John Walsh
