PSP 2018 Pen Tool Edit Nodes NOT working
Theresa711
System_Drive: D
processor: amb FX-6100 6core 3.3 GHz
ram: 16 GB
Hard_Drive_Capacity: 105TB
Corel programs: PSP 2018
Post by Theresa711 »
When I have created a shape using the Pen Tool with Create on Vector checked shouldn't I be able to go back and edit the nodes at any point? When I leave that layer to work on another and later try to go back to edit the nodes they will not show up, even if I click EDIT mode. Is there a bug or is there something new I am missing???
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: PSP 2018 Pen Tool Edit Nodes NOT working
Post by MarkZ »
Yes, if you used create on vector you should be able to edit the nodes. In the Layers palette you will see a layer called Vector1. Click on the down arrow to the left of the name. This will open the sub-layer that contains the object you created. Select that layer and now you should be able to work with the nodes - make sure you select the edit mode icon.
If that doesn't work, try resetting the program - save workspace then restart while pressing shift key.
Mark
Theresa711
System_Drive: D
ram: 16 GB
Unfortunately that is what I have been doing. And this occurs often after PSP had been closed out and reopened. This version of PSP has been very problematic for me.
