Big problem with VS 2018
sylwester
Post by sylwester »
I bought I started to test VS 2018 Ultimate on Windows 10 Pro. Windows 10 and VS2018 newly installed.
I can not save the AVC / H.264 file.
When the project (slideshow) is small (20 photos), only transitions between photos (no music, descriptions or titles) - OK working and saves the file.
When the project is big (2000 photos), the program closes when 0% appears in the progress bar.
Maybe I do not have something installed that is required by VS2018?
or something should be set.
Unfortunately, there are no installation instructions
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Big problem with VS 2018
Post by asik1 »
Are you sure? 2000 photos?
How long is this monster project?
Panasonic X900m, VXF1
sylwester
Post by sylwester »
This is a test. I did not pay attention to quality. Pictures loaded from several folders and transitions included automatically. The whole process 5 min
Project time less than 2 hours.
I've already done such projects, holiday photos. But more effort with titles, music, etc.
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
You might be exceeding VS capabilities with such large project; I have not heard of anyone doing such a large project. Who is going to watch a two hours slide show?
But, we want to try to help you and perhaps the issue is not VS but your pc. You have not given detailed specs of your pc, like main memory, hard disk speed, processor speed, etc. Also, resolution of the media. Perhaps we can offer more suggestions to get you going.
User for more than 10 years.
sylwester
Post by sylwester »
As I wrote, I've been doing such projects.
When a project made in X8 did not save the movie by editing the program.
I assumed that VS2018 did not properly load projects from X8 and that's why I tested a new project of similar size.
In fact, the only difference is Windows 10 previously Windows 7
Windows 10
ASUS P8Z77-V LK
Intel Core i7 3770
NVIDIA GeForce GTX 660
Ram 16Gb
SSD 512 x2
HDD 1T x2
aljimenez
ram: 24GB
Post by aljimenez »
OK, your pc seems capable. I can only suggest trying 100 photos and see if that works, then try 500, 1000, etc, and see if that tells you when it starts to fail. If it fails at 100, then there is a problem with the installed VS.
canuck
operating_system: Windows 8.1
Post by canuck »
I would never even consider a project with 2000 photos. It is much more efficient to break down such a project into a number of smaller projects which are much easier to edit, etc. The smaller project can then be merged into your final video.
Why would you even want to create a 2 hour slideshow?
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
Just rendered a test project to MP4, 1 hr 7 min long, 2013 images (slides), 3 sec. each with crossfade transition and title animation for information.
No issues other than edit limits of number of images that can be added to the timeline at one time.
aljimenez
ram: 24GB
Post by aljimenez »
That's good to know, but will you give more details on "limits of number of images that can be added to the timeline at one time". First, what is the limit number, and what happens if it is exceeded?
gewb
Post by gewb »
aljimenez wrote:That's good to know, but will you give more details on "limits of number of images that can be added to the timeline at one time". First, what is the limit number, and what happens if it is exceeded?
Not a "hard" number, more of a range. I select a large group of images in the resource pane and drag to the timeline. When the limit is exceeded nothing happens. Reduce the number of selections and VS works as expected.
It does seem that as more images are added to the timeline the fewer images at one time can be added next. Might be related to a buffer of some kind or the the database having limits. Or it might be related to the sum of the file sizes selected...who knows but I'm not going to spend the time and effort to find out.
Oh, numbers - most I did at once was about 100, maybe 125. At times I couldn't do more than about 40.
sylwester
Post by sylwester »
I found what causes VS2018 to close
if "Enable Hardware Encoder acceleration " is on , a large project closes the program (small works)
if "Enable Hardware Encoder acceleration " is off large and small project works
But .....
File Creation execution time when on 16 min when off 24 min in my small project.
Definitely better when acceleration is on. But what to do to make it work on large projects I do not know
I have not checked yet when the "big project" begins
sylwester
Post by sylwester »
Aha
This applies if an ACV / H.262 file or Blu-ray Disc is created.
With MPEG-4 it's OK
LeGrand
motherboard: Asus I 7 2600
processor: Intel 3.4 ghz
Video Card: NVidia GT740
sound_card: include inboard Asus
Hard_Drive_Capacity: 3 T 500SSD
Monitor/Display Make & Model: 2 Asus IPS HDMI
Corel programs: VS2019,X10,PSP2019,CDX7 WINDVD AfterShot
Post by LeGrand »
Often when I have a large slideshow project with vidéo too. I split it in 2 or 3 mp4 separately registered that I put in a new project and never had problem . It could help ??
Ford GT and Mustang lovers
gewb
Post by gewb »
sylwester wrote:Aha
With MPEG-4 it's OK
Good catch!
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
Unfortunately, AFAIK Corel doesn't define what is meant by "hardware acceleration" but usually it would mean a physical mechanism exists at the chip level that can be invoked by software eg a driver of some sort to speed things up. An external graphics card with specific features may be an example.
What the features needed are, I don't know.
However from the spec details provided, on your PC hardware acceleration ON is using memory that's not available for anything else, whereas when it's OFF, the memory is available for application use.
