PSP X9 Ultimate copy/paste/as new layer shuts me down
bonnieb1255
- motherboard: Hewlitt Packard
- processor: Intel Pentium 2.90 Ghtz CPU G4560T
- ram: 4 GB
- Hard_Drive_Capacity: 856 Gigs
- Monitor/Display Make & Model: HP 22uh LED Backlit Monitor
- Corel programs: Paint Shop Pro X9
I just purchased a new copy of PSP X9 Ultimate; it worked fine until I tried to use the function copy/paste as new layer. Then it closed out psp on me. I uninstalled and then reinstalled the program. Tried the copy/paste as new layer function and it worked that time. Then, the next time I tried to use copy/paste as new layer, it closed down Psp again. I have Windows 10. Help, please
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: PSP X9 Ultimate copy/paste/as new layer shuts me down
That function works fine here, so I can only think that something is corrupt with your set-up.
Try the Shift key trick to fix it:
If you have changed your Workspace at all, save it first so it's safe.
Then close PSP.
Open it again and hold the Shift key at the same time, hold it down until you get a message that PSP is reverting to it's default settings. Click OK.
Then you will have a 'clean' install.
This has got me and others out of trouble many times
Joëlle
PS: You will need to reset File Locations and other preferences.
Then close PSP.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
bonnieb1255
- ram: 4 GB
Thank you Joelle it worked!!! I am doing the happy dance now
Joelle
- ram: 16 GB RAM
