Brian, I need your help. Today I completed few pending system and driver updates on my Win 10 PC and now as I try to open VS Pro 2018 it loads and crashes itself after few seconds automatically. Any idea how do I get it working again?
Update: Upon an uninstall and reinstallation of the latest version of the VS Pro 18, it has been running smooth once again. Thanks for your response Ken.
Bikas Gaur
VS crashes after OS and driver update
Re: PSP crashes after OS and driver update
I have split your post away from where you posted it as it had absolutely nothing to do with the topic discussed in that thread. I realize you were trying to attract Brian Chalke's attention, but hijacking a thread is not the way to do that. I am sure Brian will read you separate post in due course.
To start the ball rolling, while you have updated your OS and drivers, is your copy of VS 2018 fully up to date? The current version is 21.2.0.113.
mukundasai111
- System_Drive: W
Re: VS crashes after OS and driver update
I require your assistance. Today I finished couple of pending framework and driver reports on my Win 10 PC and now as I endeavor to open VS Pro 2018 it loads and crashes itself following couple of moments consequently. Any thought how would I make it function once more?
Mukudasai
Mukudasai
mukundasai111
- System_Drive: W
yes, Could you Please help to solve this problem.
I need your support. Today I completed couple of pending system and driver writes about my Win 10 PC and now as I attempt to open VS Pro 2018 it loads and crashes itself following couple of minutes therefore. Any idea how might I make it work again?
Regards
Regards
canuck
Your signature says you have a Mac but here you say your are using a Win10 system. Which is correct?peter011 wrote:I need your support. Today I completed couple of pending system and driver writes about my Win 10 PC and now as I attempt to open VS Pro 2018 it loads and crashes itself following couple of minutes therefore. Any idea how might I make it work again?
Regards
If using a W10 system the do you get any error messages? Did you get any messages when installing? Did it work before installing the W10 updates? What happens if you undo the updates?
