PSPx9 Automatically Tile a Texture ?
scottb613
motherboard: Gigabyte
processor: i7-7700K Kabylake OC 5 Ghz
ram: 32GB
Video Card: EVGA GeForce GTX 1070 Ti
Hard_Drive_Capacity: 2000 GB
Corel programs: Jasc PSP 9.1 - now PSP x9
Post by scottb613 »
Hi Folks,
Something I've wondered about for a while - a long while...
If I have a small seamless texture - and I want to apply it over a large texture without changing the originals resolution - without manually copy and pasting it a thousand times - is there a way to this with less effort ?
Thanks...
Scott
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: PSPx9 Automatically Tile a Texture ?
Post by Jean-Luc »
You may use the Fill tool with this texture selected.
scottb613
ram: 32GB
Post by scottb613 »
Jean-Luc wrote:You may use the Fill tool with this texture selected.
Hi...
Thanks so much for the response - I may need a little more detail ?
I tried making a selection of the texture I want using the selection tool - but it doesn't seem to work as I need to make another selection to paint with it...
If I save my sample to my custom "Texture" directory - I can get it to show in the pallet but it's translucent and wants to be applied with the color also selected...
What I want is a complete opaque tile of the original - with the original color and scale - as if I was copying it - then manually lining it up and pasting it 1000 times - to stitch together a much larger version...
Thanks for your patience...
Scott
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Then you want patterns not textures. Textures in PSP are quite literally meant to simulate drawing or editing on a particular surface like paper, or wood. It makes for interesting effects as you paint. Which is why you get the semi-transparency effect.
Patterns are just images that repeat.
scottb613
ram: 32GB
Post by scottb613 »
Hi...
Thanks - I'll try with patterns...
Much appreciated...
Scott
