I am trying to see how to remove an object using the Object Removal Tool
1 Clicked Object Removal Tool on Tools Toolbar
2 Selected the option of Auto Selection in the Tools toolbar
3 Dragged rectangle around the object and then a marquee showed following the contour of the object to be removed.
4 But I cannot find the apply check button
Help please
Object Remval Tool apply check button PSPRo 2018
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
- hartpaul
- ram: 8 Gb
Re: Object Remval Tool apply check button PSPRo 2018
I presume you are using the Object Removal Tool which is associated with the Clone tool.
Once you have chosen that , to select the object, you do not use a selection tool, instead on the Tool Options Bar near Opacity you use the Selection Mode - like a little lasoo and freehand draw around the object . Then you choose the little rectangle nearer the Opacity and use that rectangle on the screen to choose the area you want to replace the selected object with.
Look t View > Palettes > Learning Centre to see its description of use.
