UI Problem: 2 fewer tracks are visible in X11 v X10
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
One immediate difference between VS X11(2018) and X10 is that the height of the tracks have increased so that it makes editing multi-track projects more difficult because one can see fewer tracks. The following image shows how 2 fewer tracks are visible in X11(only 5 tracks visible) vs. X10 (7 tracks visible):
Is it possible to reduce the width of the tracks in X11 to the size that they were in X10?
Thanks,
tletter
Re: UI Problem: 2 fewer tracks are visible in X11 v X10
Ummm... Have you hovered your mouse over any of the border lines between tracks? You should get upward/downward pointed arrows which allow you to adjust the height of individual tracks by dragging them up or down. And you can add more, just as you could with previous versions.
You can also change the size allocated to the preview window/library pane vertically, and the preview screen horizontally as well, in a similar way.
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
Ummm, click the Show All Visible Tracks toggle icon at the far left of the time readout line and above the column of track on/off toggle icons.
GEWB
tletter
Post by tletter »
Ken Berry wrote:You should get upward/downward pointed arrows which allow you to adjust the height of individual tracks by dragging them up or down.
In my VS 2018, I can't reduce them in height lower than the default size by dragging.
gewb wrote:click the Show All Visible Tracks toggle icon
That does it.
Thanks,
tletter
gewb
Post by gewb »
That does it.
Thanks,
tletter
You're welcome.
GEWB
tletter wrote:In my VS 2018, I can't reduce them in height lower than the default size by dragging.
No, but why would you want to? On my 32" monitor the default size is small enough as it is. But you can certainly make it larger by using that mouse hover/arrow method, and you can drag it back upwards towards the default size if you overdo it...
gewb
Post by gewb »
Ken -
I have the same resize issue as tletter - I can increase a row height but not decrease it (AMD and Intel, both Win7).
GEWB
Do you mean you can't reduce it back to the default size once you have increased it? Or just that you can't make the default size smaller? I can't do the latter either -- but think it was designed that way. But I can certainly do the former -- but NOT with 'Show all visible tracks' selected.
gewb
Post by gewb »
Ken Berry wrote:Or just that you can't make the default size smaller?
^^^ This, which is how I interpreted the original post issue. Not saying what is right/wrong or as designed, just the question. I use the Show toggle icon and just roll with it.
GEWB
tletter
Post by tletter »
Ken Berry wrote:On my 32" monitor the default size is small enough as it is.
I don't have a 32" laptop nor would I want one even if I could afford it and on my 15" laptop the track height was too large in VS 2018 as explained and illustrated.
Ken Berry wrote:But you can certainly make it larger by using that mouse hover/arrow method
Yes but the requirement was to reduce the track height as explained. GEWB offered a solution that does what I needed.
Thanks,
tletter
