Cannot Set File Locations
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
Post by Leslie »
My PSP 2018/X8/X9 will not allow me to add new file locations. The programs simply freeze,
I have shut down PSP and re-booted the computer to no avail.
This is way past aggravating.
Can someone help?
Re: Cannot Set File Locations
Have you tried resetting PSP? It's easy. Simply hold down the Shift key when you click on the desktop PSP icon to open the programme. You'll be asked if you want to reset. OK that.
Make sure, though, that you save any Customized workspace you may have created. Otherwise that will be lost in the reset.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
With the issues you've been having lately, I'm going to ask exactly what has changed with your computer. There must have been a time when PSP worked as advertised, and this (and your previously posted issue) must be relatively recent. Unless something has changed in your computer configuration programs just don't suddenly exhibit unexpected behaviour. So there must have been some change, whether it's Windows updates, installation of some software, changes to firewall and/or anti-virus settings or behaviour, PSP workspace setting and/or file location settings or other such configurations, addition of new scripts, changes to hardware or hardware configuration, etc. Can you recall when things last worked as they should and then try to remember any and all changes that may have happened to your system since then?
JoeB
Using PSP 2019 64bit
Leslie
ram: 32 gb
Post by Leslie »
Balls & Bubbles I have no idea when it last worked as I hadn't used it.
Could be a windows update, but don't remember whether it was before this problem arose. The issues concern things I don't use very often.
Otherwise, I have only added AShampoo, which is a backup program for the entire computer. That wouldn't have bothered anything.
I'm at a standstill. I could remove X8 or X9 and reinstall and see what happens.
JoeB
ram: 8 GB
Post by JoeB »
If you're going to do a reinstall then make sure to use the cleanup tool in the sticky near the top of the forum. And, once reinstalled, test the programs without using any save workspace first! Sometimes - if rarely - something in a workspace is the culprit so it's best to retest the reinstall in its default state to see if the issue(s) have been resolved. And then when redoing your file locations check to see if there comes a time after adding a location where you can't add anymore. If that happens, then the previously added location could be the culprit.
JoeB
Leslie
ram: 32 gb
Post by Leslie »
Do I just use the cleanup tool alone, or use it after I have uninstalled the program to get rid of remnants?
JoeB
ram: 8 GB
Post by JoeB »
Leslie wrote:Do I just use the cleanup tool alone, or use it after I have uninstalled the program to get rid of remnants?
To be honest, I don't know. :-( I think I saw somewhere that you do a Control Panel uninstall first then the Cleanup tool but can't remember where I saw it. I have never needed it myself. You might want to wait for a more definitive answer. A bit longer can't hurt, eh? :-)
JoeB
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
The cleanup tool is not meant to uninstall PSP but rather to clean up after an uninstall to make sure nothing was left behind.
So, first, uninstall PSP then use the cleanup tool. However, the cleanup tool should only be used if you've encountered problems attempting to reinstall PSP. It's kind of a "Last resort" tool.
Leslie
ram: 32 gb
Post by Leslie »
Ok, will do. It's been stuck on uninstalling 3rd party programs for 10 minutes. I'm using geek uninsaller.
JoeB
ram: 8 GB
Post by JoeB »
Leslie wrote:Ok, will do. It's been stuck on uninstalling 3rd party programs for 10 minutes. I'm using geek uninsaller.
You're probably better off just using the Windows uninstallers through the Control Panel.
JoeB
Leslie
ram: 32 gb
Post by Leslie »
I've been trying to uninstall the program, but it is still getting stuck for over 1/2 hr on uninstalling 3rd party programs, whatever those may be that are part of this debacle.
I'm going to try a system restore and see what happens. How frustrating.
JoeB
ram: 8 GB
Post by JoeB »
Leslie wrote:I've been trying to uninstall the program, but it is still getting stuck for over 1/2 hr on uninstalling 3rd party programs, whatever those may be that are part of this debacle.
What third party programs? I thought you were just uninstalling PSP.
JoeB
Leslie
ram: 32 gb
Post by Leslie »
I am just trying to do psp, but then that 3rd party thing comes up and just stays.
*sigh*. I'm going to try to uninstall X7 now.
Hopefully that will go well.
Leslie
ram: 32 gb
Post by Leslie »
I uninstalled and re-installed.
I still can't use Balls and Bubbles. It freezes the program. I added file locations except that that takes a long time to see the documents where My PSP Files are. At this rate it will take me hours to redo my file locations, but at least it works.
So, I'm almost back where I started before I uninstalled and re-installed.
X9 does the same thing.
I'm out of ideas. Guess just have to do things without that effect, and deal with it if I need to add files to the location file.
In 12 years I've never had a problem with any of the psp programs.
Arrrgggghhhh
Leslie
ram: 32 gb
Post by Leslie »
I'm back. I can now set locations in 2018, altho the paths take 60 seconds to appear.
However, the balls & bubbles is not working.
What do I try after uninstalling, reinstalling, using the clean up tool and not fixing the issues?
Help........
