In the last few (small number of) weeks, when my PSP Pro 19.2.0.7 x64 starts up it immediately gets into a (sort of) loop reporting a Script Error with the following text:
"An error has occurred in the script on this page
Line 0
Char 0
Error Script error
Code 0
URL http://maps.google.com/maps/api/js?clie ... uage=en-US
Do you want to continue running scripts on this page?"
I am then given an option of either Yes or No.
Regardless of which I choose (and however often I choose it) the error re-appears.
This is making the program close to unusable.
I run W10, absolutely fully up to date (Fall Creators Update came my way recently), and the System Information in the 'About PainshopPro' window is
PaintShop Pro Build Information:
Serial Number XXXXXXXXXXXXXXXXXXXXXXXXXX
Build Date Friday, 24 February 2017 @ 14:51:20
Build Mode Release (13000004)
Hardware Configuration:
OEM ID: 9
Processors 8
Processor Type Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
MMX Support No
Memory / Drive Status:
Memory Load Index 30 %
Total Physical Memory 15.96 GB
Available Physical Memory 11.11 GB
Total Paging Memory 18.83 GB
Available Paging Memory 13.21 GB
Total Managed Memory 20 MB
Total Handles: 200
Temp Drive Free Space 82.21 GB
Video Driver Information:
Bits Per Pixel 32
Number of Colors 16777216
DIB Output 24 BPP
Palette Size Non-Paletted
Resolution 1920 x 1080
Operating System Information:
Operating System Windows 10
Plug-in Information
Filter Plug-ins Loaded: 0
Import Plug-ins Loaded: 0
Export Plug-ins Loaded: 0
Format Plug-ins Loaded: 0
DLL Name Version Load State
CmdArtistic 19.00 None
CmdBase1 19.00 Partial
CmdBase2 19.00 Partial
CmdBevels 19.00 None
CmdClipboard 19.00 Partial
CmdColor 19.00 None
CmdEmail 19.00 None
CmdExternal 19.00 None
CmdFile 19.00 None
CmdGeometry 19.00 None
CmdHDR 19.00 None
CmdJGL 19.00 None
CmdLayers 19.00 None
CmdLighting 19.00 None
CmdNonGraphic 19.00 Partial
CmdOrganizer 19.00 None
CmdPhoto 19.00 None
CmdPhotoSharing 19.00 None
CmdPrint 19.00 Partial
CmdPyScript 19.00 None
CmdSelections 19.00 None
CmdSlideshow 19.00 None
CmdStandard 19.00 None
CmdTexture 19.00 None
CmdVector 19.00 None
CmdWeb 19.00 None
ToolArt 19.00 Partial
ToolObject 19.00 Partial
ToolPaint 19.00 Partial
ToolSelect 19.00 Partial
ToolStandard 19.00 Partial
ToolText 19.00 Partial
ToolWarp 19.00 Partial
WinTab Tablet Status
Driver Version: None
Again, this is simply on opening the program even before this humble user has tried to find an image to edit.
(As a new user I know that my first few posts have to be held to be checked by the Moderator. Fair enough).
Script Error on startup
crawdaddy
- motherboard: Gigabyte Z27ON-WiFi
- processor: Intel i7-7700
- Video Card: Nvidia GeForce GT 730
- Hard_Drive_Capacity: 4.5TB
- Monitor/Display Make & Model: Viewsonic
- Corel programs: Corel PSP Pro 19.2.0.7 x64
pwm
- processor: AMD A10-6700
- Video Card: AMD Radeon HD 8670D
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Acer G247HYL
- Corel programs: Paintshop Pro 2018
Re: Script Error on startup
I have the same problem. There's already an existing thread on this here:
viewtopic.php?f=56&t=62857
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
I suggest that you remove the serial number from your post.crawdaddy wrote:I run W10, absolutely fully up to date (Fall Creators Update came my way recently), and the System Information in the 'About PainshopPro' window is
JoeB
Using PSP 2019 64bit
JoeB
crawdaddy
Ouch! My sincere apologies. I did several searches for "Script Error" looking to see if it had already been discussed, and missed it (I guess because the Javascript thing foxed me).pwm wrote:I have the same problem. There's already an existing thread on this here:
If the Moderator wants to close this thread to further postings that's fine by me.
crawdaddy
ThanksJoeB wrote:I suggest that you remove the serial number from your post.crawdaddy wrote:I run W10, absolutely fully up to date (Fall Creators Update came my way recently), and the System Information in the 'About PainshopPro' window is
I see that (guess Moderator) had already done that. That'll learn me for having tried to find as much data as possible to go with the program fault report.
patman1957
- motherboard: Alienware 0XJKKD A01
- processor: 3.00 gigahertz Intel Core i7-5960X
- ram: 16276 mb
- Video Card: NVIDIA GeForce GTX 980 Ti
- Hard_Drive_Capacity: 6986.56 Gi
- Monitor/Display Make & Model: Dell S2716DG
- Corel programs: Corel PaintShop Pro X8
I have yet to see a workable reply to this issue of:
Corel PaintShop Pro X8 "An error has occurred in the script on this page." Line: 0 Char:00 Error: Script error. Code: 0 URL: http://maps.google.com/maps/api/is?clie ... 8.advanced 1&v=3.8&sensor=true&libraries=places&language=en-US Do you want to continue running scripts on this page?"
Is there a solution or has this program become worthless trash requiring a deletion of the program and reloading?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
This isn't really what this particular board is about. That error had to do with Google maps which comes from the map location function in manage mode. And deals very specifically with how the built in browser control is interpreting the JavaScript and html of the Google maps page
I honestly don't think we can fix that because as Google updates its maps code older browsers won't be able to run it.
I also have the same annoying issue, so I disabled the whole Google map integration with Paintshop Pro. The latest version I am running is 2018, and the script fails with an undefined variable/object Google.
Someone better at debugging javascript may have a look at this, but the solution to disable it is as follows - this is on Windows 7 Pro 64 bit - Paintshop installed as 32 bits.
Go to the folder: C:\Program Files (x86)\Corel\Corel PaintShop Pro 2018\Languages\EN\GeoTagging
(or to \Program Files\ if you have the 64bit install).
Make a copy of GoogleAdvanced2.htm
Edit the file above to comment out the following lines - like below:
<script type="text/javascript" src="http://maps.google.com/maps/api/js?v=3. ... "></script>
script type="text/javascript" src="../../EN/GeoTagging/js/GoogleAdvanced1.js"></script> -->
This will make this htm file do nothing - hence script problem is gone.
Editing system files are of course on your own risk !!!
regards, Harald
regards, Harald
wpslo
- motherboard: asus 1025ce
- processor: intel Atom
- ram: 4gb
- Hard_Drive_Capacity: 2 TB
Thank you very much Harald for that post .
I moved the all three Google ...htm to another folder - that worked as well
but it was your idea so chapeau .
The files were
GoogleAdvanced1.htm
GoogleAdvanced2.htm
GoogleSimple1.htm
Dunno if this has borked anything else but if it only
relates to talking to Google I really do not care; actually a result for me .
The files were
GoogleAdvanced1.htm
GoogleAdvanced2.htm
GoogleSimple1.htm
