How to mirror an image in PSPX9
Phil47
motherboard: ASUS Z170-P DDR 4
processor: i-5 6600K OC
Video Card: GTX960
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: Asus MX279
Corel programs: PSP X6 PSP X9 PSP 2018
Post by Phil47 »
How can I mirror an image in PSPX9?
It is easy to find out how to do it in Corel Draw so why not PSPX9?
Tell the truth....but gently.
Phil.
motherboard: Alienware M17xR4
ram: 6 GB
Corel programs: PSP: 8-2023
Re: How to mirror an image in PSPX9
Post by LeviFiction »
With the Mirror and Flip commands usually. Under the Image menu there is a section for Mirror and Flip. Flip is a local command meaning that the layer will flip across its own local access simply reversing either horizontally or vertically in place. Mirror is a global transform, it will mirror a layer across the Canvas's horizontal and vertical axis resulting in a mirror image on the opposite side of the canvas.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Phil47 wrote:How can I mirror an image in PSPX9?
It's extremely easy to find out how to do it in PSP also. Go to Help on the menu bar and type the word mirror in the search box. The first item that appears will be this:
Flipping and mirroring images
If you have the User Guide in pdf format you go to Help>User Guide(PDF) and also type the word mirror to get the result you need.
You're welcome.
JoeB
Using PSP 2019 64bit
Hi Phil
I have sent you a PM regarding your forum E-Mail address, can you please reply regarding this issue.
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
Ctrl+M :-)
Joëlle
Joëlle
(PSPX9 )
Wuu
Post by Wuu »
Hello,
I am using PaintShop Pro X7.
Is there a simple way to transform a layer so that it is mirrored like a real mirror does, when I put an item onto its surface?
I show it with pictures what I am looking for.
this is the source layer:
I want to transform it to this:
in order to get this:
It sounds like a noob question.
I’m not a noob.
Therefore I feel even more ashamed.
Any hints?
Regards
Wuu
Joelle
ram: 16 GB RAM
Post by Joelle »
No need to feel ashamed :-)
I have tried using Layer Styles>Reflection, but the reflection doesn't 'bend' the way you want it, hmm.
Sorry, can't help, my brain is not fully functional today!
Joëlle
PS: That's expensive pork ☺
Joëlle
(PSPX9 )
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Wuu wrote: Sat Feb 12, 2022 1:35 am Is there a simple way to transform a layer so that it is mirrored like a real mirror does, when I put an item onto its surface?
I think it is not possible with PSP.
In the mirror you want, the shape of the can of food has the same curvature as the not mirrored can.
But the text has an inverse curvature (when mirrored). They are two opposite things.
I have tested with the Polar Coordinates Effect with no luck.
:cry:
Wuu
Post by Wuu »
Thank you Joëlle, thank you Jean-Luc.
Now I’m happy that I’m not as lame as I was afraid to be. And unhappy because my problem wasn’t solved.
Strange that such a natural reflection can’t be done.
Dear Corel, is it too complicated or am I the only one to put a meat can on a mirror? :wink:
Joelle
ram: 16 GB RAM
Post by Joelle »
Splat 😁
Joëlle
(PSPX9 )
ram: 6 GB
It's complex. Keep in mind that your mirror is reflecting in 3D before you take the picture and is actually showing more of the can than would have been captured without the mirror. The big thing is in the reflection you need to delete the majority of the top part of the can, and then you need to distort the image along a curve so that the bottom touches on every point. We can do this manually by using the warp tools, I recommend Mesh Warp as it's more constrained and you can more easily control it.
Here's a really bad attempt. I used the Warp brush (warp mesh might be the better tool but it has its limitations). Would be nice if PSP offered a better deformation cage option.
Joelle
ram: 16 GB RAM
Post by Joelle »
That's excellent, I tried using the Warp brush, then the Warp mesh, but didn't get anything as good as yours :-)
Joëlle
Joëlle
(PSPX9 )
