simple squeeze issue
Stoneprod
I edited a project with my avid, and using sorenson squeeze converted it to a larg DVD file, I then loaded it up on DVDWS and selected a "good quality DVD' which I believe is 90 minutes. The "size required" then showec 4.1
However DVDWS tells me that the file is to big for the DVD, its true that the actual file I imported was 5.1GB. and I am aware that it must be around 4.4 but I thought that selected a lower quality setting on DVDWS would fix this problem and convert it down?
Any suggestions on how to simply squeeze this 5.1 down to 4.4 using DVDWS?
Thanks,
Pete
Thanks,
Pete
It's not working
Hey folks,
I have source files that are appoximately 6.5 GB. when I check the "convert to disc template" it adds .1 GB for every clip I do it to. I even had to resort to removing clips from the dvd to try and get it to fit, but no luck. What am I doing wrong? I need to get 6.5GB down to 4.4 GB. What do I do?
thanks,
cgman
thanks,
cgman
Stoneprod
Hey,
I think all that you need to do is be sure in the EDIT section of DVDWS be sure that the "convert to disk template" is checked in both the video and audio tab.
Next in the Finish menu click on the dick templates drop down box and select probably the 120 minutes option. This should convert it down to a worakble size, however 6.5 might be too big and then you would ahve to either use a dual side DVD or reduce your quantity of video.
Good luck
Pete
Good luck
Pete
It's a question of bitrate. Lower bitrate = smaller file.
Here's a handy Bitrate Calculator.
Higher bitrate = higher quality = more disc space = lower compression = less playing time.
Lower bitrate = lower quality = less disc space = higher compression = more playing time.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
lombard33
Where are these tabs located on the EDIT step? I've looked in both the VIDEO and AUDIO folders, and don't see any options at all...GeorgeW wrote:In the EDIT step, there are VIDEO and AUDIO tabs. Both of those tabs have an option called "Convert to disc template" -- make sure you check that option box to have DWS2.x convert your source files to your project settings...
Thanks,
Carole (new to DWS2.232)
- ram: 2 GB
- sound_card: Intel GMA 950
The box "Convert to disc template" also tells you something about your video.
If its blank that means that your video is already DVD compliant and so there is no need to convert it to the current disc template (Unless you have a specific reason to do so - e.g. reduce its size to fit)
If it has a tick in the box already - it will also be greyed out so that you cannot remove the tick - then this tells you that your video is NOT compliant and WILL be converted.
sigun
