VS 2018 crashes on render with IntelGPU
Desertsweeper
motherboard: ASUS x99 WS10
processor: Intel Core i7-6850K
ram: 32GB
Video Card: nVidia Quadro P1000
sound_card: Realtek
Hard_Drive_Capacity: 2TB NVMe
Monitor/Display Make & Model: 3 x ASUS 27" QHD Displays
Corel programs: VS 2018 Ultimate and Graphics X7
Post by Desertsweeper »
I ran the new Corel VS 2018 without problems on my IntelCPU+NvidiaGPU PC, but after swapping out the Mainboard and CPU to an Intel+IntelGPU I can no longer get anything to render:
Faulting application name: vstudio.exe, version: 21.1.0.89, time stamp: 0x5a6b5f58
Faulting module name: igfxcmjit64.dll, version: 6.0.0.1189, time stamp: 0x579b07f9
Exception code: 0xc0000005
Fault offset: 0x0000000000120183
Faulting process id: 0x524
Faulting application start time: 0x01d3a7166eac3913
Faulting application path: c:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
Faulting module path: C:\Windows\system32\igfxcmjit64.dll
Report Id: f83c7823-1309-11e8-ad48-005056c00008
Original system: Intel i7-6850K and Nvidia P1000 Quadro
New system: Intel i7-7700K and Intel HD Graphics 630
Driver Version: 21.20.16.4860
I should add that this is a Windows7-on-KabyLake hack so it is not supported by Wintel. But I should also mention that Magix Video Pro X renders just fine - with Intel HWA producing stunning results when compared to the previous setup (easily twice as fast). The system is very stable and everything not needed is disabled in MSCONFIG on startup. EDIT: Just tested Vegas v15 and it to renders about twice as fast on the Intel GPU than it did on the Nvidia (Using Intel QSV vs Nvidia). No crashes
I am curious to know if anyone has had this crash with the new Corel on any combo of Windows and Intel GPUHardware? And if so, can you tell me what versions of Windows and INtel Graphics driver you are running.
Thank you
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Re: VS 2018 crashes on render with IntelGPU
Post by qtrim »
Perhaps try reinstalling Corel VS 2018. Maybe it looks at the CPU/GPU when it's installing and configures itself accordingly. Could even be an anti-piracy thing, like the way Windows sometimes requires a re-activation if you change too many system components.
Using VideoStudio since old Version 7. Currently using X10.
Desertsweeper
ram: 32GB
sound_card: Realtek
Thanks for the suggestion, tried that but same problem, still crashes out when I attempt to render:
Faulting process id: 0x10a0
Faulting application start time: 0x01d3a749a2d05da3
Faulting application path: C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
Report Id: 02163233-133d-11e8-83b7-005056c00008
The file igfxcmjit64.dll is the same version Intel has been using for two years in their graphics drivers. Weird.
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
One of your difficulties is that Kaby Lake only has Win 10 support, so it must be assumed that there could be some issues with Win 7
That aside,my laptop which has the HD Graphics 630, driver 22.20.16.4836 and the Nvidia GTX 1050 Ti, driver version 23.21.13.8816 has no problem rendering, but it is using Win 10
Desertsweeper
ram: 32GB
sound_card: Realtek
RobertOZ, while I agree that Kaby Lake technically only has Windows 10 support, many have demonstrated that the two work just fine. The "lack of support" is nothing more that mIntel (Microsoft and Intel minting it) strong-arming consumers into adopting the latest versions of their products (KL/CL and Win10). And as I pointed out I can render with IntelGPU acceleration happily with Vegas and VPX so the system is working fine.
I am curious - when you are rendering, which is the "active" GPU, the Nvidia or the Intel?
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
Try turning all hardware acceleration. They are in the Preferences dialog. I suspect this is the problem. If this works, try turning some of them on to determine where failure is. Then communicate this with Corel.
User for more than 10 years.
Desertsweeper
ram: 32GB
sound_card: Realtek
Yup - turning off HWA solves the problem but defeats the purpose. It is slower than slow itself. So Corel does not support IntelGPU Acceleration?
aljimenez
ram: 24GB
Post by aljimenez »
I have a Dell XPS13 laptop with Intel GPU and HWA works, so I don't think your conclusion is valid. Something is not working with your system. You may need to do some tweaks or see if Corel support can help.
Desertsweeper
ram: 32GB
sound_card: Realtek
Corel Support were unable to assist on this one. They had me delete, re-install, different profiles etc etc. So I have switched to Magix Video Pro X that works fine on Windows 7 with Kaby Lake - super fast render times with the iGPU.
Advice to users: If you want to use Corel on Kaby Lake or Coffee Lake you will need to upgrade to Windows 10 if you are still on Windows 7.
enlighten_me
Post by enlighten_me »
Sorry to update an old thread. I had this problem with Kaby Lake crashing on render. I have a Dell XPS 15 i9570. Everything rendered fine on my old Lenovo X220.
I tried what one of the users here suggested, but the OPPOSITE. I turned on all Hardware Acceleration in Preferences. So far, it seems to be working.
Desertsweeper
ram: 32GB
sound_card: Realtek
enlighten_me they fixed this with an update and now it works fine to turn them on
