Using Photo Impact XL and getting the following error
Manic
Post by Manic »
We are using Win XP HE, 512MB Ram
ledit.exe - Application Error
The instruction at "0x73ddllc7" referenced memory at "0x0000004" The memory cannot be "read".
I have changed the memory module...
All updates on Windows and Photoimpact have been done.
Thanks for your time.
Will
2log
re: Using Photo Impact XL and getting the following error
Post by 2log »
Have you tried reinstalling the software? Uninstall PhotoImpact from the Control Panel.
When you install a software, the installer extracts temporary files needed for the installation on a temp folder. These folders are usually:
C:\Windows\Temp
C:\Documents and Settings\[User Name]\Local Settings\Temp
If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The Local Settings folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open Windows Explorer, go to Tools > Folder Options > View and check show hidden files and folders. You can now open the Temp folder from the Documents and Settings folder and delete the files there before you make a new install. :wink:[/b]
