The only tools I've tried to use in Paint Shop Pro 2018 are the selection tools, and I can't get them to work as they do in the demos and tutorials. The autoselection tool gets some of the area I want selected, but not all, and selects random areas in the rest of the image. Same with the magic wand. I get more or less random areas selected. Using the add or remove selection option just changes what random objects are selected. I've watched the videos several times, and even copied the demo image they use in the video, but still get the same result.
I contacted Corel technical support, and they just sent me the link to the tutorial on selection tools, which I'd already seen.
(The text on the right side of this post might have errors, because there is a pop-up from ParticleShop covering that area, and I can't get rid of it.)
Any help would be appreciated.
Selection Tools Don't Work as Advertised
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Selection Tools Don't Work as Advertised
I don't use Auto Selection because I don't think it works all that well either. However, I use Magic Wand quite a bit. It does not select random areas for me as long as I choose the proper setting in the Tool Options palette - i.e., Match Mode, Tolerance, Contiguous or not, all depending on what I'm trying to achieve and the composition of the image. We would need a lot more detail with specifics about the settings you are choosing for the Magic Wand, specifically what you are trying to select, and the parts that are being selected that you don't want to select that should not be selected if you have the proper settings.FrankDK wrote:The only tools I've tried to use in Paint Shop Pro 2018 are the selection tools, and I can't get them to work as they do in the demos and tutorials. The autoselection tool gets some of the area I want selected, but not all, and selects random areas in the rest of the image. Same with the magic wand. I get more or less random areas selected. Using the add or remove selection option just changes what random objects are selected. I've watched the videos several times, and even copied the demo image they use in the video, but still get the same result.
JoeB
Using PSP 2019 64bit
JoeB
FrankDK
- motherboard: HP Envy 23
- processor: Intel Core i5-4570T CPU 2.90GHz
- ram: 8 GB
- Hard_Drive_Capacity: 5 TB
- Monitor/Display Make & Model: HP Envy 23
- Corel programs: PaintShop Pro
That makes me feel a bit better. I thought I was just not doing it right. I'll try the magic wand tool.
Thanks.
Thanks.
JoeB
- ram: 8 GB
If you're not used to PSP's selection tools, you might also want to experiment with the Freehand Selection tool which, in the Tool Options palette under Selection Type has four different options. The Point to Point works well for some images, and Freehand for others. I haven't spent much time trying the other 2 options there. You'll also have to get familiar with how using the other items on the Tool Options bar help with making your selection look better - i.e., Smoothing, Feather, and checking the Anti-Alias (the latter almost always a good bet for anything except square/rectangular/all sharp edges and corners selections).FrankDK wrote:That makes me feel a bit better. I thought I was just not doing it right. I'll try the magic wand tool.
Thanks.
JoeB
JoeB
Sort of related to this....how do you get the selection outline to go away????? After I select an area with any of the tools I can not get it to go away no matter what I press or click. Its maddening. It just sits there an taunts me.
Kathy_9
- Hard_Drive_Capacity: 2TB
Keyboard Shortcut: Ctrl+Dwjb76 wrote:Sort of related to this....how do you get the selection outline to go away????? After I select an area with any of the tools I can not get it to go away no matter what I press or click. Its maddening. It just sits there an taunts me.![]()
Menu Option: Selections -> Select None
JoeB
- ram: 8 GB
Or simply right click in an area outside of the selection.wjb76 wrote:Sort of related to this....how do you get the selection outline to go away????? After I select an area with any of the tools I can not get it to go away no matter what I press or click. Its maddening. It just sits there an taunts me.![]()
JoeB
JoeB
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Another option in menu/selections is to toggle the marquee on or off - but this is dangerous as you can turn off the marquee to see your image without the interference but the selection is still active. You may forget you have a selection on the go and wonder why something doesn't work; I've done this more than once.
Mark
JoeB wrote:Or simply right click in an area outside of the selection.
Kathy_9 wrote: Keyboard Shortcut: Ctrl+D
Thank you all!!!MarkZ wrote:Another option in menu/selections is to toggle the marquee on or off - but this is dangerous as you can turn off the marquee to see your image without the interference but the selection is still active. You may forget you have a selection on the go and wonder why something doesn't work; I've done this more than once.
