Corel VideoStudio X10 will not launch
sclinko
Corel programs: Corel VideoStudio Ultimate X10
Post by sclinko »
This is a relatively recent issue I've been having (as of the past day) where APLoading.exe loads, but the application itself does not launch (the loading screen vanishes after a few minutes, but nothing else). It's odd because I was working on the program yesterday and there have been no major Windows Updates (Windows 10).
I have tried deleting and re-installing the program multiple times, I have tried hard and soft resets, as well as a driver update and security rollbacks. Is it a corrupted file or an issue with a security override or something else?
Re: Corel VideoStudio X10 will not launch
Hi sclinko
And welcome to the forums.
Try turning off the internet to see if the program will launch, just a thought?
Can you try using the cleanup tool to remove / uninstall the program.
http://forum.corel.com/EN/viewtopic.php?f=1&t=59847
This folder is used to reset the program, Renaming the 20.0 to 20.0-old
You should also re-name this folder after running Cleanup.
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\20.0
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
Thinking out loud here...
When you shut down Windows, do you do full shut down or do a sleep mode? If sleep/fast boot/restore to last mode type thing then the VS executable might still be running - open Task Manager and check the loaded processes. If VS is listed, shut it down then try to relaunch as usual.
