"Import Graphics" Problem
POST
Post by POST »
I'm trying to import a vertor file made in Illustrator. But I keep getting this message.
"The import command only works with closed path data. Unable to find a closed path in this file."
Also what is the best way to get make an object from a "alpha channel"?The "convert to vector" in the "path editor" doesn't work too good. My object usually is not too smooth and it has way too many points. Is there a better 3rd party program?
Thanks.
bryave
illustrator file
Post by bryave »
I've tried an illustrator file to be imported but have not experienced such problem as yours. Maybe you should stick with the closed path data error. Try other illustrator file that seems to be a closed path. ^_^
†bryave
