split a long mpeg2 file
diablo
i captured a long vhs tape and it doesnt have any spots to make a clean cut anywhere on the tape or mpeg file, so i guess i have to split it on two dvd's unless there is an option in videostudio take put things onto two dvd's
my capture card captured it as low as possible bitrate so i cant lower that so how can i use videostudio 9 to split the 2 hour 40 minutes or so mpeg2 file to fit on two dvd's
is there an option to fit on two dvd's if not is there a transition i can use so the first part of transitions smoothly when i place second dvd in dvd player
any trick out there to do this
thanks
thanks
Dont think there is an option to use two discs.
I don’t know what quality you will get?
Have a look at this calculator; it will give you an idea to the bit rate settings.
http://dvd-hq.info/Calculator.html
Using VS 9 from the burner module select the cogwheel lower left. Look at the Change MPEG settings.
I would use these as a guide to create a template to render the video from the edit window.
The only other option is to split the video in the edit window, rendering each half to a new video, then burning to two discs.
Best of luck.
P.S.
If you are using Lpcm audio change it to Digital Dolby, this will reduce your file size.
Best of luck.
P.S.
diablo
THoff
THoff
Half D1 resolution uses about half the number of horizontal pixels of Full D1. Depending on whether you are using NTSC or PAL, that's 352x480 and 352x576, respectively.
You can prepare your MPEG files for this resultion by selecting "Custom" for the output format, choosing MPEG as the file format, clicking "Options", and then changing the "Compression" settings.
Another way to do this is to use the Template Manager to create a new output template with these settings -- the new template will then appear on the drop-down menu when you select "Create Video File".
diablo
THoff
