Nature of the problem
I use PaintShop Pro 2018 to design huge banners. To do so, you need to be able to add marks for the usable area etc... A practical tool to do so would be predefined shapes, e.g. rectangles. It is possible to draw rectangles of any size. However it is impossible to set the size of rectangles numerically to more than 10000pixels. This makes rectangles useless for this purpose!
There is a completely useless possibility to have have two (2) digits after the coma - what shall this be good for? A pixel is the smallest unit I can use to specify a rectangle! Isn't it?
Properties of your source files (format, file size, where did you get it?)
pspimage, 13.8k x 7.6k large
What devices are involved and their mode of connection?
none
Project Properties
n.a.
Output format
n.a.
Error Codes (if any)
none
BUG: size of rectangle limited to 10'000 pixel
TerraD
- motherboard: ASUS Crosshair iV
- processor: AMD Phenom 1090
- Video Card: NVIDIA Gforce GTX560
- sound_card: none_-_really_none_even_if_4_chars_is_too_short
- Hard_Drive_Capacity: 6TB+
- Monitor/Display Make & Model: Syncmaster 1920x1200
- Corel programs: PaintShop Pro 2018 and X2
- Ravelli
- motherboard: GigaByte GA-970A-UD3P Rev. 2.x
- processor: AMD Phenom II X6 1090T
- ram: 16 GB
- Video Card: MSI GeForce GTX 1050 Ti GAMING X 4G
- sound_card: ESI Maya44 eX
- Hard_Drive_Capacity: 11 TB
- Monitor/Display Make & Model: BenQ G2222HDL
- Corel programs: PSP since 1993
Re: BUG: size of rectangle limited to 10'000 pixel
Hello TerraD,
a pixel is the smallest unit of a bitmap image, but not for vectors. While editing them, you can move them 'between' pixels. That is more accurate for the case you want to scale up your image later. But you can change this behavior in the settings/preferences, in the 'Units' tab there is checkbox for 'Snap to center of pixel while moving'.
Since there are bugs with aligning vector objects exactly with the above mentioned setting, I keep it off - so I can manually scale an object to what I need.
Good luck with it,
Ravelli
Good luck with it,
Ravelli
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
TerraD,
you may create a new image :
-> Blank canvass -> Paper -> size A0
Width is 14025 pixels.
When the image is displayed, you may trace manually a rectangle from left to right which is more than 10000 pixels width. It displays 10000 but is greater.
