Just wanted confirmation really, I've not been able to create a slideshow that has visible buttons for navigating, then it occured to me that I need to put in a graphic (button) to represent each control, and in the slideshow options assign the various navigation controls to each button (presumably each one must be in a separate slice).
Is this correct?
online slideshows created with PI10
2log
re: online slideshows created with PI10
There are presets available for creating slideshow webpages for PI 10. Go to Object Libaries of EasyPalette and under Template Library, select Slideshow.
Choose a template and drag it to the gray area. Modify the designs if you want (text and background) but not the buttons and main window. Save it as html using File - Save for web - As HTML... [Ctrl+Alt+S]. Then you'll have to modify the source code (HTML code) with Notepad to change the pictures and the number of slides you will use.
