coreOrganizer.dll vanishing
- arturox
- motherboard: Yes-very-bored
- processor: 3-90 gigahertz Intel Core i3-7100
- ram: 8 Gigs
- Hard_Drive_Capacity: 250Gb SSD+1 Tb SSD
- Monitor/Display Make & Model: Acer 22 inch
- Corel programs: PSP 9-01 and PSP 2022
PSP 2018 version 20.2.0.1 32 bit installed on a Win 10 fully updated PC.
Take it as a given, I have not recently uninstalled anything either Corel or PSP related, infact I've not uninstalled anything recently.
Yesterday evening PSP was working okay, today it would not start, reporting "coreOrganizer.dll was missing... etc."
As I have three PAID for installs of PSP 2018 on different computers, I shipped in a copy of the missing .dll from one of the other installs.
Interesting... After around 30 seconds this new shipped in .dll vanished from the filer window... Just vanished.
Tried a few times more same result.
Anyone have any idea what's going on?
Obviously I have since done a complete reinstall of the ************************* thing, and so far PSP 2018 works okay.
Ax
Ax
- arturox
- ram: 8 Gigs
Re: coreOrganizer.dll vanishing
Yes well!
After doing some more work it transpires it's Windows Defender "Virus and Threat" protection that's doing the removal.
Why the expletive it should suddenly want to instantly remove "coreOrganizer.dll" from PSP I have no idea... Way way above my knowledge grade.
Anyway, I've now added that to the exclusion list, brought in a copy from another machine, and so far PSP 2018 is working okay... Yes I've forced Window Defender to re-scan and rebooted a couple of times.
Time will tell...
Ax
Time will tell...
Ax
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
I'm not surprised it was an AV program that caused the problem given your description. But I am surprised that you weren't given a warning window from Defender advising that it had discovered a "threat" and quarantined it. Then again, it's Microsoft's Defender so I guess I shouldn't be surprised that it just does what it wants to without even checking with the user. There are other threads dealing with PSP slowing down and/or freezing where - at least in some cases - it appears that Defender is the culprit.
JoeB
Using PSP 2019 64bit
JoeB
- arturox
- ram: 8 Gigs
Well yes I did get a warning from Defender but it warned me about a "Win32/Lodi" whatever the naughty word that is.
There was no mention of coreOrganizer.dll.
The only thing I could think was making the coreOrganizer.dll vanish as soon as I imported a new copy from other machines was Win Defender so I switched off the the Defender "Virus and Threat" protection.
Then I reinstalled the whole PSP 2018 again and while Defender "Virus and Threat" protection was off, PSP worked okay, but as soon as I switched it back on, coreOrganizer.dll again vanished and PSP was stuffed, which obviously confirmed my suspicions.
Again, Defender "Virus and Threat" protection only reported the "Win32/Lodi" which it said was High risk.
Anyway Defender's problem seems to have been sorted now I've entered "coreOrganizer.dll" in its exceptions file.
Interesting you mention...
Thanks for your input.
Ax
Nb: The other computers with PSP 2018 installed, one Win 10 and one Win 7 have not encountered this problem, nor have their 2018s become slower.
Both are also protected by Defender.
Ax
I must see if I can find those threads as PSP 2018 now works very slowly compared to a while ago. (But at least it is working).There are other threads dealing with PSP slowing down and/or freezing where - at least in some cases - it appears that Defender is the culprit.
Ax
Ax
JoeB
- ram: 8 GB
Look for forum subjects like Slow Start, Slow load, etc. They are quite current in the list because of the continuing discussion regarding the issue. The idea that Defender was a contributor to the issues (besides the latest Windows 10 Fall Creators updates) has only recently been discovered and discussed.
JoeB
JoeB
- arturox
- ram: 8 Gigs
Thanks for that bit 'o info it saved me a lot of searching...
Interesting reading.
Ax
Ax
FCH
- Corel programs: corel
Hi - This also happened to me.
Now my Paint Shop Pro 2018 is not Working
I hope I will be able to re-install.
TimW
- motherboard: ASUS M5A99FX
- processor: AMD FX8350 8 core 4.0GHZ
- Video Card: AMD Radeon HD 6900 Series
- sound_card: On Board
- Hard_Drive_Capacity: 256GB SSD
- Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
- Corel programs: PSP X8, Knockout 2
This bit of info might shed some light on the subject.
https://www.microsoft.com/en-us/wdsi/th ... Win32/Lodi
JoeB
- ram: 8 GB
Are you suggesting that Terry's Windows Defender didn't remove the .dll but instead it was done by a piece of malware on his computer named WIN32/Lodi? And perhaps it was the WIN32/Lodi that removed the DLL before it (Lodi) was removed by Defender? Or perhaps that WIN32/Lodi has corrupted the .dll and Defender has deleted both the virus/Trojan and the .DLL?TimW wrote:This bit of info might shed some light on the subject.
I ask because while the link does indicate that WIN32/Lodi is a threat, nowhere in that link or other searches is there any information that would indicate that this particular .dll file (which is a Corel developed .dll) is being flagged by Defender as WIN32/Lodi (i.e., a false positive identification of the .dll). It appears to be a .dll file shared by more than one Corel program.
So given that this seems to be a very rare occurrence with users of Corel programs, unless Defender is suddenly seeing this .dll as a false positive then it must be finding something that it believes is WIN32/Lodi. And either Defender or Lodi must be removing the .dll. And Defender shouldn't be doing so unless it is identifying it as a virus/Trojan when, in fact, it isn't unless it has been corrupted in some way that flags it for Defender.
JoeB
JoeB
- hartpaul
- ram: 8 Gb
JoeB wrote:Are you suggesting that Terry's Windows Defender didn't remove the .dll but instead it was done by a piece of malware on his computer named WIN32/Lodi? And perhaps it was the WIN32/Lodi that removed the DLL before it (Lodi) was removed by Defender? Or perhaps that WIN32/Lodi has corrupted the .dll and Defender has deleted both the virus/Trojan and the .DLL?TimW wrote:This bit of info might shed some light on the subject.
If Win32/Lodi removed the dll and then was flagged AND removed by Defender then when the OP "shipped in" a new copy of the dll there would have been no Win32/Lodi to remove it. This suggests that the dll is the thing that is removed by Defender and that the Defender recognition needs to be updated by Microsoft to recognise the dll as safe.
That would require Microsoft to apologise and do an update and get that out to all win 10 users.
- arturox
- ram: 8 Gigs
Interesting posts... But I still have no idea, even after much searching what "Win32/Lodi" is, or what put it on my computer, though I guess if it is a false positive, see my bit of madness at the end...
As to the other things discussed. I'll summarize what I found. (Somewhat summarized).
Yesterday 25/01/2018 (UK) Win Defender flagged up "Misleading:Win32/Lodi" as a High risk and quarantined it.
A little later PSP 2018 failed to run, presenting IIRC two error messages, the second of which noted, "coreOrganizer.dll" was missing.
I looked in the PSP 2018 appdir and noticed, indeed the "coreOrganizer.dll" file was missing.
Ran another computer with 2018 installed, and over the LAN transferred a copy of said file to replace the missing one, within a few second, well maybe 10-15 second this new added "coreOrganizer.dll" vanished before my eyes.
Not sure I was really seeing this, I again transferred the replacement "coreOrganizer.dll" into PSP, and again it vanished, did this action a couple more times, each one vanishing shortly after dropping into PSP.
I noticed a Defender notification flag in the corner of my Taskbar and opened it up, this time it had multiple Win32/Lodi entries quarantined.
I'd not yet fully twigged what might be happening, but had a suspicion, so as part of my precautions I switched of Defender's AV section.
Thinking PSP 2018 had encountered some sort of corruption problem I set about reinstalling it, and thereafter it worked okay.
Switched the Defender AV back on and immediately "coreOrganizer.dll" vanished.
Switched off the Defender's AV, shipped in a copy of "coreOrganizer.dll" from the other machine and PSP 2018 started to work okay.
Looked at the Defender's AV quarantine list in detail and counted...
Ooeer! The number of quarantined Win32/Lodi entries exactly matched the number of "coreOrganizer.dll" files that had gone missing.
Ping! ping! ping!...
I clicked up the Defender's AV config section and put an entry for "coreOrganizer.dll" in the Exclusion list.
With Defender AV now running again and a couple of forced re-scans to check... Thereafter... and it's now a day later "coreOrganizer.dll" remains in place and PSP 2018 is working.
Now you might think I'm a bit mad (Comment if you wish), but just for the desire to know, I renamed my existing and working "coreOrganizer.dllXXX" file.
I'd kept one Win32/Lodi in the Defender Quarantine box which now I clicked for Defender to Restore, and, and as if by magic... "coreOrganizer.dll" popped into view next to the renamed "coreOrganizer.dllXXX"
I think that indicates without any doubt, Windows Defender, for whatever reason, way above my knowledge grade is to blame.
Arturox
Nb: Apologies for the length of the above, but I though my fix and the end result worth noting.
Ax
Arturox
Ax
Sugsilla
- motherboard: Asrock z77 pro4
- processor: Old
- Video Card: Nvidia 970
- Hard_Drive_Capacity: shows red
- Monitor/Display Make & Model: 2X Benq 24"
- Corel programs: PSP 2018 ultimatum
Yep Similar story here too.
To keep story short, while playing other games, my windows defender announced this threat Misleading:Win32/Lodi, for some of paint shop pro 2018 dll files, that I can’t remember. (I really need my two hands to keep up some shooters, but it was diferent than mentioned above.) And whit haste I pressed remove button.
Now of course after that nothing in paint shop pro didn’t work. Not even a uninstall… (maybe it was My win 10 defender still , defending somethin…)
And now things get little bit odd. When I try to make fresh instal from my DVD, my defender will go straight to vigilante mode. And prevents installing giving this same “High security alert”
Misleading:Win32/Lodi In file SetupXML.dll
Funny thing about this is that, I already installed and used PSP 2018 for about three weeks now. And only problem that I got, was this slowing down start up, past couple a days. (that seems to be reported here in forums too.)
So I’m not sure is this false positive, and/or does those two things relate together?
RoxioCreatorNXT6.exe has similar issue with Win32/Lodi. I wrote to Corel and I was replied: "Please be advised that this issue is being worked on and we'll update you as soon as we can."
TimW
JoeB; I can neither confirm nor deny that the link I posted (from Microsoft) contained a positive solution to the problem discussedJoeB wrote:Are you suggesting that Terry's Windows Defender didn't remove the .dll but instead it was done by a piece of malware on his computer named WIN32/Lodi? And perhaps it was the WIN32/Lodi that removed the DLL before it (Lodi) was removed by Defender? Or perhaps that WIN32/Lodi has corrupted the .dll and Defender has deleted both the virus/Trojan and the .DLL?TimW wrote:This bit of info might shed some light on the subject.
JoeB
- ram: 8 GB
I don't think you're mad in this case, because I'm the same in wanting to get to the bottom of this type of mysterious event on my system and willing to take as many steps as possible to troubleshoot the issue.arturox wrote:
And your troubleshooting brings up an idea about how AV programs could at least make it easier to troubleshoot false positive issues. (I'm not sure if all AV programs operate like Defender but it's easily possible that most do). Whenever an AV program identifies a supposed piece of malware, the notification window should show BOTH the name of the malware it is identifying AND the name of the file - as it exists on your computer - that it is identifying as that specific piece of malware. That would allow the user to Google the actual file name and try to make an independent decision about whether or not the file was legit and being flagged by a false positive. It might also help those searches find relevant topics indicating whether others have posted about that particular file being improperly flagged, and make it easier to figure out what that file was actually used for. As it is, a malware name like WIN32/Lodi is actually a pretty generic malware name and searches for it don't provide anything really worthwhile in the way of relevant information.
I've never checked to see if my AVG or my Malwarebytes do that or just identify the same as Defender does.
JoeB
JoeB
