Cropping in PSP 2018
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
Q1: I've removed the Crop toolbar, now how do I remove the 'Thirds' grid?
Q2: Can I disable 'Maintain Aspect Ratio' as the default?
Q3: What is supposed to happen if I click Clear (4th icon from left)? Here, nothing happens.
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Cropping in PSP 2018
Post by LeviFiction »
1) Right-click on the crop and deselect it from the context-menu
2) It should remember the settings from the last applied crop. So make a crop rectangle, deselect "Maintain Aspect Ratio" and accept the crop. Now it should no longer be default. Until you turn it back on anyway.
3) If you have an active crop rectangle on the image, clear should remove it. Effectively letting you start over.
terrypin
ram: 32 GB
Post by terrypin »
LeviFiction wrote:1) Right-click on the crop and deselect it from the context-menu
Thanks, done.
Thanks, done.
Thanks, I''ll do that from now on. I was using the 'Clear' button, which fails:
https://www.dropbox.com/s/73qjcvysvpvhe ... 1.jpg?dl=0
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
If I have an active crop rectangle on an image I can clear it either using the context menu, the clear button on the little toolbar, or the clear button on the main tool options bar.
JoeB
Using PSP 2019 64bit
terrypin
ram: 32 GB
Post by terrypin »
Are you running under latest Win 10 update?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Terrypin is correct. Clear on the top toolbar does not clear an established crop rectangle, but clicking again on the image does clear it - I guess the assumption is that you want to clear the rectangle and redraw so that is when the old is erased and then new started.
ram: 6 GB
Clear works for me, latest version of Windows 10.
terrypin
ram: 32 GB
Post by terrypin »
Puzzling that we are getting different results.
Typing 'winver' into the Run box I see mine is 'Version 1703 (OS Build 15063.850)'.
I think the term 'latest version' can be misleading, as not only do Windows 10 updates apparently get issued over days or possibly weeks but users can postpone them, sometimes inadvertently. For example, yesterday I had a notification pop up while I was in the middle of a tricky Excel operation, along the lines of "We have an important update we'd like you to pick up...". It offered a "Later" button which I hurriedly clicked. Just recalled that on reading the last posts here. So I'll reboot later today ... in the tentative hope that it might get PSP 2018 loading in less than its current 67 secs.
BTW, testing my trivial cropping issue again before composing this, there was a 5 second interval after clicking the Crop tool before it became available.
And after clicking Clear icon in the Tool Cropping Options, top left, which doesn't clear the rectangle for me, if I then click inside the rectangle that still sometimes doesn't clear it.
JoeB
ram: 8 GB
Post by JoeB »
terrypin wrote:Are you running under latest Win 10 update?
Don''t be silly! :-) I have so far managed to avoid Windows 10 and, as shown in my profile, use Windows 8.1. It might have a few annoyances but all of my programs still work as they're supposed to.
JoeB
ram: 6 GB
Winver says Version 1709 (OS Build 16299.192)
Though I should note that I've never had an issue with the clear button not working. It's entirely possible this has to do with the UI redraw issues people have. That it does in fact clear the rectangle but the view doesn't update to reflect this. The interaction with the mouse forces an update. Hard to say as I can't test it though.
hartpaul
ram: 8 Gb
Post by hartpaul »
If you allow the Floating Crop tool bar (below each image crop area ) then Clear at top and Clear on the Floating Crop Toolbar both work correctly.
I think terrypin is trying to make PSP look and work as closely as it can to Jasc PSP8 from which he upgraded. If he accepts the Floating Crop Toolbar (FCT) then there is no problem . It is not a great learning curve to use that FCT.
JoeB
ram: 8 GB
Post by JoeB »
hartpaul wrote:If you allow the Floating Crop tool bar (below each image crop area ) then Clear at top and Clear on the Floating Crop Toolbar both work correctly.
Probably why it worked for me. I also had the floating toolbar active. I actually find it convenient to have the crop to new image button so close.
JoeB
ram: 6 GB
Yup, I can duplicate the issue by turning off the floating toolbar.
