When I photo edit, I typically start in raw camera lab, make some basic adjustments and then continue in EDIT. I then commonly do an HDR merge (single raw image) and make further changes...and save. At this point I use Smart Photo Fix and make final "tweaks". I am now starting to experiment with Perfect Effects. After the steps describe above is this a good point to employ Perfect Effects? Or should I start earlier in the editing process??
This is my first time on the forum. Thanks
work flow question...PSP >> perfect effects
