besides having the application crashing frequently I have currently the problem, that I am just not able to export two specific photos. If I start an export (any option, I tested serveral configurations, from full resolution to small resolutions), it just takes forever. Both images have comparable high resolutions, because they are orginally stiched to a panorama. However, the application should either return with an error or best, just do the job.
I have uploaded the original images and my corrections xmp files here: https://www.dropbox.com/s/aupfvmc8btgck ... t.rar?dl=0
Please respect the copyright of the photos.
Can anyone reproduce it?
@Corel: Could you please debug this, should be pretty easy to see what causes the problem, if it is reproducable.
Thanks in advance,
Chris
Export just hanging up on specific high resolution photos
prairiedog
- Corel programs: Aftershot Pro 2
Re: Export just hanging up on specific high resolution photo
Hi Chris
I've just tried it on Aftershot Pro 2 under Windows 10 and both photos were exported without problems. I don't have access to Aftershot Pro 3 so unable to test the current version.
Hope that's useful,
Demetris
Hope that's useful,
Demetris
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
I tried it on the newest ASP 3 on Linux (Ubuntu 14.4 LTS) - not working!
I had that problem too with some big panoramas of my own.
I noticed that "jpg Fullsize" (JPG-Vollbild) is not working but jpg-contactsheet (JPG-Korrekturbogen) works!
So ASP seems to be able to process but has problems with fullsize ...
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
Thanks Hannes and Demetris for testing.
I can also now confirm that I have the same problem on another Computer with Linux and AfterShot Pro 3. My initial test was on Windows 10 and AfterShot Pro 3. Both computer have plenty of RAM >=12GB and should be fast enough for processing.
The resolution cannot be the only problem, I have already exported other panoramas with even higher resolution.
@Corel: Can you please create a bug report for you development team? Or where do I have to do this?
Kind regards
Christopher
Kind regards
Christopher
hannes_hab
- System_Drive: Z
- ram: 16 GB
regards Hannes
austria
austria
hannes_hab
- System_Drive: Z
- ram: 16 GB
or: https://www.facebook.com/CorelAfterShotPro/
but - I had the experience that they do noting ...
even simple things are not solved - for example - they say that the nikon coolpix P330 is supported - but color and contrast are totally wrong - I do the following: with exiftool say that the nikon coolpix P330 files are nikon coolpix P7800 files - and everything is fine - reported this at several channels (about 2 years ago) - but noting happend - so I still run exiftool ...
so I wish you the best ...
regards Hannes
austria
austria
Thanks for the link. I just send this problem there.
Too sad that they do not work on this, I could easily do it myself, but then they would have to release the source code!
