Edit window
Re: Edit window
You could always use Live Screen Capture which comes with VS (Capture tab > Live Screen Capture) or it's a separate icon on your desktop if you haven't removed it.
Or you could simply type out what is in the Properties box in a new post here...
canuck
operating_system: Windows 8.1
Re: Edit window
Post by canuck »
Roy,
what happens when you are in the project mode and single step on the timeline?
What is the time duration shown for your project?
It would also be really helpful if you were able to post a screen snapshot so we could see what your screen looks like.
canuck
Re: Edit window
Post by canuck »
Rollason wrote:I would love to but unfortunately my keyboard, 'print screen', doesn't appear to be working. Is there some other way of doing this? Roy
How are you doing the PrintScreen? What makes you think it is not working?
Re: Edit window
Hi Roy
First right click any clip and choose Properties.
Pressing Keyboard Alt + Prt-SC should copy that active window to the clipboard.
Now you have to paste that to an image editor to save/create an image ( keyboard Ctrl + V to paste)
Alternatively you can try pasting to a “word document”, if that works, right click that image in Word for Save as Picture, save as Jpeg to your hard drive, maybe to Pictures
Insert that image to your post, if unsure how to do read this post.
http://forum.corel.com/EN/viewtopic.php?f=63&t=57659
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Re: Edit window
Post by tletter »
Well you could simply take a digital photo of the screen and upload it here.
tletter
Rollason
motherboard: Intel GM 45
processor: Intel core i3 2 duo P8400 2.2GHz 1066 MHz 3MB
ram: 3GB
Video Card: 1GB ATI Mobility Radeon HD 5650 Graphics Card
sound_card: JBL 2.1 + SRS Premium Sound
Hard_Drive_Capacity: 320GB
Re: Edit window
Post by Rollason »
The preferences checked are:
GENERAL
Undo.
Relink checking.
Media library animation.
Auto save interval, ---- 10mins.
Instant playback target preview window.
Background colour ---- Black.
Display title safe area on preview window.
Display track hint on preview window.
Pal.
EDIT
Resampling quality ---- Good.
Show DVD sub title.
Default auto fade ---- 4secs.
Apply auto cross fade automatically.
Default transition effect ---- Random.
Random effects ---- customise
CAPTURE.
Record directly from CD.
Snapshot format ---- JPEG
Snapshot quality ---- 100
Deinterlace for snapshots.
Stop DV tape when capturing stops.
Show recover DVB-T video warning before capturing.
I would add that when selecting one of the coloured boxes from the library the Play button works OK for one cycle and then reverts to Pause again immediately after making a second attempt to play. Playing any other video, ie. an advert for example, the play button for that video works fine. I hope that all of this is some help
Re: Edit window
Sorry but
We are referring to you providing the “properties” of the video file, not the “preferences” of the program
With your clip on the timeline, right click the clip and choose properties, what are they?
canuck
Re: Edit window
Post by canuck »
Roy,
could you please answer the questions asked on Jan 15?
Rollason
ram: 3GB
Re: Edit window
Post by Rollason »
Sorry about that, had to leave the screen and come back to it. Memory isn't what it might be. So, hope I have it right this time.
FILE.
File Name. .... C\users\user\videos 2018-01-15171011_132736_Import_002.MPG
File format. .... PAL DVD
File size. .... 194.884kb (191 MB)
Duration. .... 252.080 seconds
VIDEO
Video type. .... MPEG 2 Video. Upper field first
Total frames. .... 6302 frames
Attributes. .... 24 bits 720 x 576 4.3
Frame rate. .... 25 frames per sec.
Data rate. .... variable bit rate (max. 8500 kbps
AUDIO.
Audio type. MPEG audio layer 2 files
Total sample. .... 12,099,840 samples
Attributes. .... 4800 Hz 16 bit stereo
Layer. .... 2
Bit rate. .... 224 kbps.
Re: Edit window
Hi Roy
It does not make sense, those properties show the video to be correct, bog standard mpeg2.
As you would expect when importing from the DVD Disc. although 4:3 I would have expected 16:9, but not a problem.
The name indicates the recording date and time which is normal, everything looks ok.
I would have advised that you re-install X9 except you have installed X10 and have the same problems.
I have tested the Import Digital Media from Capture tab using X9 and have no problems, my disc imports ok and plays without problems.
Very strange, I am at a loss as to what to suggest.?????????
Maybe Ken and canuck have ideas
Rollason
ram: 3GB
Re: Edit window
Post by Rollason »
Hello, has this been given up on? I'm unable to use the programmes and would appreciate any further comments. I have reinstalled both programmes and am getting the same result. Any help would be appreciated. I have 11 videos to edit and no programme working! Thank you, Roy :cry: :cry: :cry:
Re: Edit window
Hi Roy
Hell no!.... we don’t give up.
When you uninstalled did you use the Cleanup tools.
Download links from this post
http://forum.corel.com/EN/viewtopic.php?f=1&t=59847
Your video files are bog standard Mpeg2 DVD and should not be giving these problems.
It does not make sense at all.
It is possible that there is a problem with your pc, maybe picked up a virus, I realise you did not wish to hear that.
Have you run your anti virus program to scan for problems
Are Windows Updates current?
What happens if you use the Libraries sample Mpeg4 video files, do they play ok, or have similar issues.
canuck
Re: Edit window
Post by canuck »
Rollason wrote:Hello, has this been given up on? I'm unable to use the programmes and would appreciate any further comments. I have reinstalled both programmes and am getting the same result. Any help would be appreciated. I have 11 videos to edit and no programme working! Thank you, Roy :cry: :cry: :cry:
I asked this earlier but you never responded.
