Joëlle, your solution worked, except I didn't want to merge it with the mirror as the reflection fell on the lip of the mirror, which wouldn't be reflected in that area and removing the reflection there also removed the mirror lip. But what I did discover is that, if I put the reflection on the blue glass layer, then copy it to a new image, I could separate the reflection from the object and remove as much or as little as I wanted. I was also able, now, to tweak the reflection with a blur.Joelle wrote:This is what I do when using the Layer Styles Reflection tool:
Duplicate the image in the Layers Palette.
The select the blue glass (very pretty!).
Promote the selection to new layer.
Apply the reflection to the top layer.
Make the bottom (original layer) invisible by clicking on the eye of the layer.
The top 2 layers: Merge visible.
Remove the unwanted reflection.
I used PSPX9, but assume that 2018 is the same.
Joëlle
Gawd, this forum really needs to give the participants a better file size allowance.
I hope you can see it.
