I am going to give that a try, if I can figure out how to get the trial versions of both on my Windows VM. I downloaded the Windows trial of Aurora 2018 this morning but when I started it I was told that I had 0 days left in my trial. Since I have never installed the 2018 version on my system I assume it has to do with the old Aurora version on the Mac side, although that seems odd.JoeB wrote:
You are, of course, correct. I have actually only tried Aurora with single images (tone mapping) because I don't have any bracketed images so I never really considered that it's best used for brackets. And given I don't usually do bracketing, only tone mapping on a single image, I can achieve the same effects just with Luminar.
You could, if you want to spend the time, try opening Aurora with a script using a single image, uncheck the Tone Mapping option at left and hit the Create HDR button. When the image opens in Aurora you could then open any 3 of your bracketed images and you'll get them in the workspace and hit Create HDR again and see if that actually uses just your bracketed images and does so properly. The only edit you'd have to do with the script is to have it return the finished image to PSP as a new image rather than as a layer on the existing image. Just a thought.
Oh! And if you did try that, when you save you'd have to do Save As, use .tiff as the format (at least that's the format I use in the script to do lossless saves), browse to your Documents file, click on the copy of the original image that was saved as Aurora_temp.tiff (or whatever name you chose in the script to use) so that the processed image could overwrite the existing temp image and save it then close Aurora. Otherwise Aurora will try to save the file in whatever format it was originally (like .jpeg) and in the same folder from which you opened the files.
I have contacted MacPhun asking them why I can not run Aurora 2018 on my VM and will have to wait for their response. I will also try Luminar, although I am not sure that it adds much to what is already available in PSP. Still, I find the ability to use PSP as a main tool with all of these other tools basically available as "plugins" through the scripting to be liberating. It means that I no longer have to switch from tool to tool, exiting one to run another one. It is very, very nice and I expect it will change the way I process images.
