I can play clips with no issues, but I am unable to play the project back so I can edit video and audio together. When I try to play my project back I get invalid parameter [19202.1:1]
Yes, I have enabled audio play back. Yes, the track are enabled. Yes, ripple edit is turned on... I can play the clips back with no issue, I simply get the error stated when I try to play the project back.
Tracks I am using: Video is an MP4, 1 title overlay, 1 title image jpg and one voice track with two wave files.
I am using Video Studio X10.5.0.60 (64bit Ultimate)
This is my first post, and I am not sure what other information you will need.
VS X10 - Project Playback Invalid Parameter
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: VS X10 - Project Playback Invalid Parameter
I am going to guess something wrong with the voice track files? Remove them orjust disable the track to see if you get the same error.
Use other ideas like that to pinpoint where the problem is: disable titles, don't use any transitions, etc. Perhaps that will identify which media file is giving the problem. Give your project properties.
User for more than 10 years.
I notice that one of the clips in the timeline, the overlay and title tracks, are stored in your One Drive i.e. in the Cloud. I can't help wondering whether that might be your problem. I can't see your audio files being a problem since they are standard .wav format, though as Al has already said, they can't be ruled out.
But though you might be able to play the Cloud clips individually, when you switch to Project mode, Video Studio in effect has to do a temporary render on the fly, and sourcing those clips from the cloud might be a step too far.
So what I would first do would be to transfer those files from the cloud to an actual hard drive and see if that makes your project playback work.
I didn't catch that. I ended up making a new project and moving stuff over then everthing was happy.
