Strange Color Cast...?
- hartpaul
- ram: 8 Gb
Re: Strange Color Cast...?
The other thing to do is to open those image thumbs in Aftershot Pro whick I think is one of the +(ultimate items) with 2018 - PSP2018_AfterShot3Installer.exe.
Check if the color variation is still there. I think there have been other threads about NEF files not showing true colors in PSP. Not sure if the problem was solved or if the final answer was to process the raw in the native Nikon raw processor.
MickG
- processor: AMD Phenom II 945 Quad Core
- ram: 12GB
- Hard_Drive_Capacity: 12TB
- Monitor/Display Make & Model: Dell SE2717
- Corel programs: PaintShop Pro X7
Hi hartpaul.hartpaul wrote:The other thing to do is to open those image thumbs in Aftershot Pro whick I think is one of the +(ultimate items) with 2018 - PSP2018_AfterShot3Installer.exe.
I did open them in Aftershot3 (it's actually the 'standard version that comes with PSP2018..
Anyway following JoeB's most recent post, I've reinstalled PSP X7 and opened the images again, this is the 4th reinstall and the weird color is still there
Here is the screenshot of the Image Information I notice it says that they 'Have been modified'...I don't have a clue what those modifications could be, but perhaps if I could trace the modifications I could revert them back to the originals? Is that possible I wonder? Doesn't it follow that if I had made any modifications permanent by using 'saved as' , those modifications would show up everywhere else, right?
Also, (different item alert!! PSP2018 Clone tool problem!!) FWIW, I tried the clone tool in PSP X7 with a grayscale image and it works perfectly.
I hope this helps,
Thanks again,
MickG
- hartpaul
- ram: 8 Gb
Is your camera one of the ones supported by PSP. What camera is it and you might check the list of supported Nikon cameras - and perhaps contact Corel - how about on their Facebook page to point out how it works in Aftershot but not in PSP.
You might also change the settings in your camera to the smallest image and lowest quality NEF image (and take some more moon images) to make it easier to send samples to Corel or post on line so that others can check it out on various versions of PSP and see if they get the same problem.
Also just a tip about posting images - crop to include only the most important parts. Your last posted image shows the Learning center and full materials and layers palette as well as the left side toolbar and all of the organizer - This full screen capture made it difficult to read the important part which was the image information. We already know that you were using and showing X7 (mentioned in text) so no need to include the very top showing the name of the PSP version.
Dijenga
- motherboard: Micro Star International
- processor: Advanced Micro Devices
- ram: 8gb
- Video Card: ati 5750
- sound_card: Soundblaster X-Fi
- Hard_Drive_Capacity: 1tb+
- Monitor/Display Make & Model: 2 ea 23" HP Monitors
- Corel programs: PSP(U) X8,X9,2018 VS(U) X8 & X10
The most likely way to get the help you're looking for would be to upload one or more of the problem images (or even a couple cropped portions of one or more of the images) in the original format that you are trying to edit.
Posting a "screenshot" in this instance is counter productive if you want answers.
Still learning, but here are a few of my favorite shots: https://www.500px.com/ccjr221
MickG
- ram: 12GB
Sorry about the screenshots...as you suspected I was showing the program name and the interface that I was using, thinking that that might be relevant. I'm using a Nikon D750, full frame, 24MP camera and (in this case an 80-400mm Nikkormat lens) no filter...I haven't been able to find a list of supported cameras anywhere, but I can't imagine that this camera wouldn't be supported - one of the best cameras on the planethartpaul wrote:Is your camera one of the ones supported by PSP. What camera is it and you might check the list of supported Nikon cameras - and perhaps contact Corel - how about on their Facebook page to point out how it works in Aftershot but not in PSP.
I just tried the 'to remove a color cast...' option in the Smart Photo Fix menu in Adjust mode. It does remove the offending color, but when I 'remove the sampling point' it comes right back!...don't know if that means anything...?
I've spent a long time trying to figure out if there's a 'history' of the 'modifications' that Image Information indicates have been made, but I can't find any such history.
I also experimented in the 'Adjust' mode - in Smart Photo Fix I can remove the color cast by desaturation, and playing with brightness, contrast etc., of course I lose the blue sky, the reason for shooting the pictures in the first place, but I guess no color is better than that horrendous purple...or whatever it is, but see what happens to the image when saved as a .tiff file. (#13) and when I try to upload the image (as per Dijenga's suggestion) resized to 950px and at 100% (#19)...?
Anyway, I'll probably continue to 'experiment' (till I lose my mind completely
...but if you can think of anything....
Thanks again
MickG
MickG
- ram: 12GB
Thanks Dijenga,Dijenga wrote:The most likely way to get the help you're looking for would be to upload one or more of the problem images (or even a couple cropped portions of one or more of the images) in the original format that you are trying to edit.
Please see my most recent reply to hartpaul.
I'm trying to figure out a way to upload an original file without having to change it, in order to resize it...! Is there a way that I can accomplish that, that you know of ?
Thanks again
MickG
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Upload it to any number of cloud storage sites, or file sharing sites. I really love my Google Drive. Or Dropbox. Of course if you're not up for creating an account somewhere you can use several websites that allow for sharing files like WeTransfer. Uploadfiles.io etc.
As these aren't forced photo upload sites they won't perform resizing or automated editing. So they should be exactly the same.
It just needs to be a service that allows you to share a link anyone can download from.
- hartpaul
- ram: 8 Gb
List of supported cameras (they claim)
https://www.paintshoppro.com/en/product ... tech-specs
TimW
- motherboard: ASUS M5A99FX
- processor: AMD FX8350 8 core 4.0GHZ
- Video Card: AMD Radeon HD 6900 Series
- sound_card: On Board
- Hard_Drive_Capacity: 256GB SSD
- Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
- Corel programs: PSP X8, Knockout 2
MickG I know this is not going to help much but, I have a friend that uses a Nikon D750. She also gets an occasional purple image. Sometimes with flash & sometimes in broad daylight. So far there has been no solution.
MickG
- ram: 12GB
hartpaul wrote:List of supported cameras (they claim)
LeviFiction wrote:Upload it to any number of cloud storage sites, or file sharing sites. I really love my Google Drive. Or Dropbox. Of course if you're not up for creating an account somewhere you can use several websites that allow for sharing files like WeTransfer. Uploadfiles.io etc.
Thanks LeviFiction,TimW wrote:MickG I know this is not going to help much but, I have a friend that uses a Nikon D750. She also gets an occasional purple image. Sometimes with flash & sometimes in broad daylight. So far there has been no solution.
I used to have a subscription to a site called Jalbum...I'll check and see the status, perhaps that'll do the job. Update: I just renewed my subscription to Jalbum! Once I figure out how it works (it's been several years since I was on that site) I'll upload the images.
Thanks hartpaul, I never thought to look there...it looks like all Nikon models are supported - (how could they NOT support the best cameras out there
Thanks TimW (I think!
Again, thanks everyone for your help.
MickG
