All my DVD-RWs are suddenly "write protected" and
macwino
motherboard: Asus P45 - P5Q-E
processor: Intel E8600
ram: 8 GB
Video Card: BFG nVidia Radeon GTX 280 OC - 1GB
sound_card: on board audio
Hard_Drive_Capacity: 2.5 GB
Monitor/Display Make & Model: Asus 22 inch
Post by macwino »
I am using the pre-August 2005 version of MF4. I just upgraded my burner from a Pioneer DVR-106D to a Pioneer DVR-110D. No software was involved in this upgrade. It was a straight swap of the drives.
Since making this upgrade, when I go to burn a DVD-RW using MF4, I get an error message that the disc is write protected. I also can't erase the disc in MF4. But if I use another program such as the default one that comes with Windows XP, the disc is eraseable.
So for some reason MF4 now sees any DVD-RW disc that is inserted into the Pioneer DVR-110D as write protected, although it didn't do this with my old burner from Pioneer. Does anyone have any ideas as to how I can remedy this situation?
I haven't wanted to install the recent MF4 upgrade because that might just add yet another variable into the mix and I've not wanted to do that. MF4 worked with the DVR-106D. It doesn't work with the DVR-110D, at least insofar as DVD-RWs are concerned. I've not experimented with a DVD-R yet.
Thanks. Robert
GeorgeW
Post by GeorgeW »
Is it only with DVD-RW's that you have previously recorded on, or is it for a brand new DVD-RW also :?:
George
macwino
ram: 8 GB
Post by macwino »
I can't say for sure. I tried it with several DVD-RW discs, one of which may have been fresh from the box. I have no fresh DVD-RWs that I can be sure of at this point, although I expect a new batch to arrive from Amazon in a few days.
Robert
GeorgeW
Post by GeorgeW »
do you have "packet writing" software installed -- the kind that let's you drag-and-drop files to your dvd discs like it was a hard drive? If so, disable such software to see if it helps...
If the XP software can erase the disc, what happens when you erase it -- will MF allow you to write to the disc after being erased :?:
George
macwino
ram: 8 GB
Post by macwino »
First, let me again state that this problem arose only after I upgraded my burner from the 106D to the 110D and that no software changes or additions were involved in this upgrade. With that said, let me go to your questions.
As far as I know, there's no packet-writing software installed. I never installed the Data Add part of Ulead MF4, which is what I think you're referring to. Nor do I have any other burning software installed, except what might have come as part of XP. If it comes with XP, then it's there, although I've never used it and don't know what it's called, etc. Again, if that is the problem, it was there when the 106D was installed and MF4 didn't have this problem.
With respect to your second question, I did try erasing the disc with the XP software and it said the erase had been done. The I tried to burn the DVD that had been erased with MF4 and I still got the write protected error message.
Robert
GeorgeW
Post by GeorgeW »
The drive is relatively new -- it could just be a matter of the Firmware needing an upgrade to recognize your media. Not all drives recognize all brands of discs right out of the box...
George
macwino
ram: 8 GB
Post by macwino »
I'd accept that, except that I upgraded from a Pioneer 106D to a Pioneer 110D. One would expect that any firmware would be cumulative and that there ought not to be problem in this regard. But I will check into it in any event, although I still think this is an MF4 problem, not a Pioneer problem. Thanks.
GeorgeW
Post by GeorgeW »
of course you are correct -- it could be that MF4 needs a burning patch to work properly with the new drive as well.
George
macwino
ram: 8 GB
Post by macwino »
Well, I decided to give installing the August 2005 update and see if that made a difference. It did. I no longer get the error message and I can burn to DVD-RWs again.
Thanks to all for your assistance.
Robert
