VS 10.5 issue with 3D transitions
richinri
Video Card: nVidia
Corel programs: PaintShop +, Particle Shop, VideoStudio
Post by richinri »
Anyone else having problem with the 3D transitions? I can reproduce a complete program lock up (VS 10.5) 100% of the time with many of them. Support had me go thru hoops and last night a total clean up and re-install only to reinstall the same issues. Example: Use the Folding Box 3d Transition. Put it as a transition and play it through once. You will shortly be doing control-alt-delete because you won't be able to do anything else.
Richard
"I have a few screws loose that will never be tightened." :lol:
Re: VS 10.5 issue with 3D transitions
Hi Richard
Hmmm
First have a read here?
http://forum.corel.com/EN/viewtopic.php ... 98#p351212
I created a project and have not had problems so far
Attached, rename the file removing the .txt
Opens with X10.5
Are you able to create a project using the sample images and transitions that are causing this problem.?
flying box - Copy.VSP.txt
rename to remove txt then open using CVSX10.5
(32 KiB) Downloaded 92 times
