Rotopen - two paths simultaneously?
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Is there a way to use Rotopen and have two travellers moving along two separate paths simultaneously?
Using Rotopen, we can create a clip showing two travellers moving along two separate paths sequentially but I'd like to have two travellers approaching each other at the same time.
Thanks.
Re: Rotopen - two paths simultaneously?
Post by BrianCee »
I can move two objects around the screen independently but not using just Rotopen because I can't find a way of saving the path which you draw - I feel sure I have done that in the past and it saves the path to the path library / custom
I can do it using the either a drawn path or the pre-supplied paths and Customise Motion as that allows you to save paths
I can do this sort of thing
https://youtu.be/y4L8jGHHzg4
tletter
Post by tletter »
BrianCee wrote:I can do this sort of thing https://youtu.be/y4L8jGHHzg4
Thanks for the idea Brian.
