PaintShop Pro 2018 Ultimate JavaScript (and other) Error
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PaintShop Pro 2018 Ultimate JavaScript (and other) Error
Post by hartpaul »
I have installed PSP 2018 and after initially having the problem, once I installed the Update 1 , it works just fine.
The version number with Map globe selected and a fresh image :
And two examples showing it working with some others I did earlier.
So it has been fixed for some. If others with the problem have removed used clean up tool and downloaded a fresh copy of the program and installed that and they still do not get it working then there may be something system specific.
I am using Windows 10 V1607 and have managed to hang onto that by setting it as a metered connection and when the nag screen comes up to upgrade about once a day I just click remind me later.
JCBrown
motherboard: 2A9C 1.0
processor: 2.80 gigahertz Intel Core i7 860
Video Card: AMD Radeon HD 5700 Series
Hard_Drive_Capacity: 15TB
Monitor/Display Make & Model: HP 2710 [Monitor] (27.2"vis)
Corel programs: PSP 2020U, PhotoMirage
Post by JCBrown »
Hi Paul,
As I indicated before, I purchased 2018 in November of last year, and from what I can find, the install program was the final version as was the patch. I have not installed any patches since then. Also, I installed both on my desktop and my laptop from the same installation file, and I only have the problem on my laptop (Surface Pro 4, not on the desktop. So, it's still a strange problem.
I'll try a reinstall. You mention downloading the main program again. Where can one find that?
So far as I know, Corel gives you 30 days to get the program unless you pay more to all downloads after this period (which is ridiculous, as is 30-day support).
Thanks,
John
John CB
PSP 2020 Ult
JCBrown
Post by JCBrown »
I reinstalled PSP2018 and the map worked. The install gave me 20.2.0.1, which, I presume is the latest version. I did not try the patch from the site as the program tells me that there are no updates. I'll leave well enough alone.
I do hate having to reinstall programs when nothing has changed and almost everything works. Usually, a reinstall does not resolve minor problems. Here it did. Strange.
John CB
PSP 2020 Ult
hartpaul
ram: 8 Gb
Post by hartpaul »
Congratulations.
I suspect (unproven of course) that they may sometimes fiddle with the program a bit making minor changes that are not big enough to place in an official Update. So easier to replace the older version on download site with a slightly updated version so that the advice to redownload and install amazingly works.
I note in the mail I received concerning my order that:
="If you are unlocking a trial, there is no need to download
the software again. Simply launch your trial and enter the License
Key(s) provided below. You will then have a fully functioning
version!"
So after uninstalling and cleaning up after a problematic install then downloading the trial and activating it to get the full version should give the latest version. Cannot verify if that also provides the 32 bit version as well though as the trial seems to be the 64 bit version.
ephophex
System_Drive: J
Post by ephophex »
Just as an FYI: this apparently is NOT new to Pro 2018.
I just encountered exactly the same issue in PaintShop Pro X6 (16.2.0.20 x64 running on a Windows 10 machine); so apparently the root cause has been lurking in the code for quite some time. My way around it:
1. In "Manage" view, move the error message notification box to the upper right corner, just below the mode buttons
2. Click the "No" button
3. QUICKLY (before the box can re-appear; this will be difficult, and might take several tries), click the thumbnail view mode button
4. The message will re-appear.
5. Use Windows task manager to kill PaintShop
6. Restart PaintShop
*IF* you managed to switch modes on Step BEFORE the box re-appeared, when you restart Paintshop, it will run normally.
It's not a great solution; but it works.
josephlin wrote:Dear All,
We apology does not give a quick action for this JavaScript error. Start from this year, we received some bug reports about JavaScript error that happened when user switching to Map View in Manage tab (mode). It causes the application cannot work anymore since this message will pop up always and block all your operation. (See snapshot below)
- Affected PSP version: Before PSPX5 ~ PSP2018 GM (PSP2018 update1 version already included this fix)
- Root cause: PSP leverages Google API to support map view display but new API requires more advanced embedded IE version (IE11) to present a correct result. Before PSP2018 update1 version, what the embedded IE version we adopted in PSPX9 and prior version is IE9.
- Solution: This hotfix can update the embedded IE version of PSPX9 from IE9 to IE11 to resolve the compatibility issue.
- Hotfix download link: http://dwnld.paintshoppro.com/updates/X ... Hotfix.exe (PS: Please noted this hotfix is only available for the PSPX9 SP2 (19.2.0.7) version)
For the user who encountered this issue, please install the hotfix and give it a trying. If you meet any unexpected issue, please reply to the forum and we will feel free to follow up. Thx.
patman1957
motherboard: Alienware 0XJKKD A01
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 16276 mb
Video Card: NVIDIA GeForce GTX 980 Ti
Hard_Drive_Capacity: 6986.56 Gi
Monitor/Display Make & Model: Dell S2716DG
Corel programs: Corel PaintShop Pro X8
Post by patman1957 »
The reply by PWM DID WORK for my system though I do not understand WHY it worked.
cjhob
Post by cjhob »
Hi folks,
I’ve been using Paintshop Pro since the mid 90s, when it was still owned by Jasc, and the Map feature has never worked properly on any of my computers, any version of Windows, or with any version of PSP. I’m currently using PSP 2018 on Win10.
The nature of the failure has varied over that time but usually PSP doesn’t hang. I can continue using all the other features. It has sometimes involved a message about javascript problems (as now) but often just a message saying it can’t find an Internet connection.
After so many years of experiencing this problem I’m not expecting Corel to fix it. I guess I’m just registering a “me too” here… but it would be nice to have PSP working as advertised.
Do they read these posts? Do they care?
My work-around has always been to use a different program for mapping. I’ve found GeoSetter to be pretty good.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
I tested today with PSP 2019 and the problem is still there: I have the javascript error message.
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
Jean-Luc wrote:I tested today with PSP 2019 and the problem is still there: I have the javascript error message.
Y'know, I tried something with a related ap...
Try this: with the PSP ap, right-click on it. In the context menu, select Properties. When the Properties window comes up, click on the Compatibility tab. Under the Compatibility tab, click on the troubleshooter button. Then follow the prompts. Maybe that will fix it. (I'm still exploring the reach of the "incompatible program" issue).
Jean-Luc
Post by Jean-Luc »
Hi Ehume,
from what other users are saying (on the French group), it seems the problem is not Corel but Google. Other softwares have the same problem : Geosetter, Photoshop, Playmemories (Sony), ...
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
If I open the geotagging webpages in chrome, the web console shows three errors. Two of them are unimportant. The third is InvalidClientId. Suggesting that either Corel has not updated their license, or there is a typo in the url, or that Google has once again changed their system and what once worked works no longer.
So, I created my own project in Google Cloud console, turned on the maps places api, and created a key to call the maps javascript. Then I replaced the maps api url with my api key and now I can geotag my photos. I never geotag my photos so it's kind of a waste of effort. But still, it works.
The obvious downside is it costs $0.007 per map load. Places calls are free up to the first 100,000. But if I load the maps 1000 times in a single month it'll cost me $7. So best to use Corel's account where possible.
Jean-Luc
Post by Jean-Luc »
LeviFiction wrote: So best to use Corel's account where possible.
Are you saying that Corel is paying Google instead of me when I load maps through PaintShop Pro? :o
ram: 6 GB
Technically I am saying there is a problem with Corel's account with Google which would explain the issue. And that my only fix puts the cost of using the system on you instead of Corel. Essentially I have no fix.
hartpaul
ram: 8 Gb
Post by hartpaul »
I woud be guessing that Corel is now wishing they had never introduced the mapping feature and other similar features that are reliant upon protocols that are outside their direct control.
If Google were to change the protocols each year that would cause PSP to have to change their program them each year or make special hot fixes and they would be unlikely to make them available for all versions of PSP back to when the mapping feature was introduced.
I have only used the feature on a few test images to check when users report problems. I did without back at Jasc PSP 8, and X2 - X4 (it seems to have been introduced in X5).may be useful for those that do a couple of trips and need to organise images based on geolocation, but when you have over 100000 images , going through and setting geolocations is a major and unneeded project.
Monteiro
operating_system: Windows 8.1
Post by Monteiro »
I
I have also this problem. Who to solve this in Corel PaintShop Pro 2018???
Tks in advance
