PaintShop Pro 2018 Ultimate JavaScript (and other) Error
spitfrog
motherboard: NZXT N7-490
processor: Intel I5-10600K 6C 12T 4_8GHz
ram: 32 Go DDR4
Video Card: Radeon RX 6750 XT 12GB
sound_card: AE-5 Plus
Hard_Drive_Capacity: 6To
Monitor/Display Make & Model: AOC Q3277 + Wacom Intuos 3 A4
Corel programs: PaintShop
Re: PaintShop Pro 2018 Ultimate JavaScript (and other) Error
Post by spitfrog »
+1 here
On the same computer, I've PSPX9 32/64 script errors, and PSPX5 working fine with the globe *
* after a tweak for PSPX5:
Add DWORD "Corel PaintShop Pro.exe" value : 2af8 in HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION
crawdaddy
motherboard: Gigabyte Z27ON-WiFi
processor: Intel i7-7700
Video Card: Nvidia GeForce GT 730
Hard_Drive_Capacity: 4.5TB
Monitor/Display Make & Model: Viewsonic
Corel programs: Corel PSP Pro 19.2.0.7 x64
Post by crawdaddy »
spitfrog wrote:+1 here
I'm not prepared to edit the registry. A step too far to make a routine "utility" program work.
kalidor
motherboard: Dell Inc. 083HX3 A11
processor: 2.40 gigahertz Intel Core i5-2430M
ram: 8Gb
Video Card: NVIDIA GeForce GT 525M
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 750
Monitor/Display Make & Model: Generic PnP Monitor (15.3")
Post by kalidor »
Hi Spitfrog,
Done that before and no joy althought it does work in Picasa.
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
I have a workaround for X9 64bit (perhaps for X8 and X7 64 too)
It's 2018 files, so this does not solve this problem for 2018
You need to replace files from
C:\Program Files\Corel\Corel PaintShop Pro X9 (64-bit)\Languages\EN\GeoTagging
with the content of this archive (backup files before)
You need also tweak the registry to made PSP compatibility with IE (it's important)
For me, it's work fine on Win10 16229.248 - IE11 and PSP X9.2.0.7 64b
If no, it's easy to roll back. If you still have script errors, initialize PSP with Shift key, and retry.
PSP_compatibility_mode_IE.zip
(777 Bytes) Downloaded 499 times
GeoTagging 2018-64-EN.zip
(54.56 KiB) Downloaded 521 times
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
kalidor wrote:Hi Spitfrog,
Hi kalidor, a french user JBLA74 spoke about Geosetter, and I found this solution on the support forum. It doesn't work for everyone, unfortunately.
kalidor
ram: 8Gb
Post by kalidor »
Magic, worked great, Thank you very much. I have been for the past week involved with Corel technical help to no avail, so I will send them your solution if you have no objections.
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
No objection, so do it ;-)
kalidor
ram: 8Gb
Post by kalidor »
Just checked , it doesn't work with the 32bit, but hey ,who cares.
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
Yes, I know that, it's a little more tricky for 32bit, you can try this files
There's a readme file in the archive
Geotagging for 32bit.zip
(53.96 KiB) Downloaded 314 times
I hope Corel will release a fix soon, it's annoying.
kalidor
ram: 8Gb
Post by kalidor »
Works great. Thanks
bosman
processor: i5-5300U 2.3GHz
Corel programs: Painshop Pro 2018
Post by bosman »
spitfrog wrote:I have a workaround for X9 64bit (perhaps for X8 and X7 64 too)
This worked!.. Thanks very much. Win 10 Pro 64 b.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Unless I misunderstood something, Spitfrog said it wouldn't solve the problem for PSP2018. But you say it worked, and your profile says you are using 2018. So did it work for you with PSP2018?
JoeB
Using PSP 2019 64bit
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
JoeB wrote: Unless I misunderstood something, Spitfrog said it wouldn't solve the problem for PSP2018. But you say it worked, and your profile says you are using 2018. So did it work for you with PSP2018?
It's a little confusing, I'm a little lost with all these files too. :wink:
What I did :
- Replacing all files from the folder Geotagging X9(32b) with X5 files
- Replacing all files from X9(64b) with 2018(64b) files, that's why I said that it doesn't work with 2018 (64b) :)
- Add a key to registry (the same for 32 and 64bit)
In fact, we don't need to replace all files, just 2 or 3 are needed, but it's more simple like that. For other language, it's become very hazardous because geotagging used english files AND foreign language files... C'est le bordel as we said back home :D
Jack Armstrong
System_Drive: B
Corel programs: PaintShopPro X9
Post by Jack Armstrong »
pwm wrote:Update: I got this response from Corel tech support:
Try resetting your internet settings.
1. Press WINDOWS KEY + R
2. Type INETCPL.CPL and hit OK (this will pull up Internet Options).
3. Go to Security tab and hit “Reset all zones to default level”.
4. Go to the advanced tab and click Restore advanced settings and then go ahead and click the RESET button.
5. Check "Delete personal settings" option.
6. Click Reset.
7. Click OK.
8. Relaunch the installer and/or the software.
I couldn't see how that would make any difference, and since the 32bit version works OK, I declined to change my security settings and they closed the ticket. It's a feature I never use, so I'll just have to remember to never click the "globe" icon.
This worked for me!
I was having the same problem as you after replacing my failing hard drive and then reinstalling X9 and going through the short tutorial that hung in map mode. Worse, every time I brought up X9 it would come up in map mode so no way to use the program. The above solution apparently fixed the problem. For whatever strange reason, Corel ignores default browser and brings up Internet Explorer which I have never used. My IE has the problem with java script, possibly because it has never been upgraded. The changes to security are only for IE, so for me I could not care less.
THANKS FOR THE FIX!
2nd thoughts: I think that what this fix might be doing is to turn on Javascript in Internet explorer, which may now be called MS Edge.
pwm
processor: AMD A10-6700
Video Card: AMD Radeon HD 8670D
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer G247HYL
Corel programs: Paintshop Pro 2018
Post by pwm »
For what it's worth, I just checked my IE security settings and I have "scripting" and "scripting of Java applets" both enabled. These were the defaults.
I use Edge or Chrome, but IE is the current release. (11.248.16299.0)
