PaintShop Pro 2018 Ultimate JavaScript (and other) Error
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: PaintShop Pro 2018 Ultimate JavaScript (and other) Error
Post by JoeB »
kalidor wrote:Hi thanks for the advice. I have only just bought and installed the programme so I was feeling my way round and clicked on maps to see what appears. I don't think I'll click on that for awhile. I had to uninstall and then reinstall so everything at the mo is ok. :D
If you're new to the program you should be aware that it has 2 default workspaces - Essentials and Complete. The selected workspace when first installed is Essentials, which is supposed to be a way for new people to get familiar with the program without all of the options that, in Corel's opinion, might confuse some people. If you would rather have all options available, including being able to fully customize the workspace, then you have to choose the Complete workspace and then save your workspace file so that it will always be your default workspace.
JoeB
Using PSP 2019 64bit
To move between Essentials and Complete you just need to right click anywhere in the workspace. In the drop-down menu which appears, at the very bottom is Workspace. You can between Essentials and Complete there.
troisieme
Post by troisieme »
I have had this same problem with both Paint Shop Pro X9 and Paint Shop Pro 2018. I have gotten similar advice from Corel technical support, which did not solve the problem. It seems as if they are not aware of the generality of this issue, and that they did not fix it in going from one version to another of the software.
So I am wondering if any of the competing software out there has a mapping function, or if there is a standalone app that can do the mapping? I would still use Paint Shop Pro for editing, but avoid clicking on the globe? Any suggestions?
buck+276
Post by buck+276 »
I was having the same problem on both 32 and 64, Google maps error code, it rendered the program useless, here's what I did to resolve it. Hold down Shift and double left click on the Paintshop Icon, it will ask you if you want to take it back to a factory reset. It only takes seconds and its a lot quicker than uninstalling and reinstalling it......FAIR WARNING........ it will remove downloaded Plug Ins and Scripts, they stay on your computer, just have to reinstall them. Basically it removes any changes or saves you have done, but as far as I have seen, will not affect any photo work you have done. The odd thing that did happen, I did this first on the 64bit version and it fixed the problem on the 32 bit version without me having to do anything to it. Good luck.
pwm
processor: AMD A10-6700
Video Card: AMD Radeon HD 8670D
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Acer G247HYL
Corel programs: Paintshop Pro 2018
Post by pwm »
Thanks for the tip. I tried that to no avail. I still get the script error.
JCBrown
motherboard: 2A9C 1.0
processor: 2.80 gigahertz Intel Core i7 860
Video Card: AMD Radeon HD 5700 Series
Hard_Drive_Capacity: 15TB
Monitor/Display Make & Model: HP 2710 [Monitor] (27.2"vis)
Corel programs: PSP 2020U, PhotoMirage
Post by JCBrown »
troisieme wrote:I have had this same problem with both Paint Shop Pro X9 and Paint Shop Pro 2018. I have gotten similar advice from Corel technical support, which did not solve the problem. It seems as if they are not aware of the generality of this issue, and that they did not fix it in going from one version to another of the software.
Google Earth. The Pro version is free.
Magix Movie Edit Pro Plus/Premium has Travel Route Animation and if there are images on the timeline with coordinates, TRA will map them. However, the main goal is to animate a route, but you can save the map with the image locations and then work on that. Below is a screen shot of the interface. The route can be turned off, leaving just the pins. A year ago, Magix had a very similar java script problem that was most annoying. It would work in one patch, then was broken in the next. This went on for quite a while until it was fixed, hopefully permanently.
Corel should take heed and fix this problem. I have the javascript problem on one computer, but not on the other, so this type of thing must make it harder to determine the problem.
John CB
PSP 2020 Ult
mckinnell
motherboard: Gygabite
processor: Intel Core i3 4150 CPU 3.50GHz
ram: 8 GB
Video Card: GTX750
sound_card: built in
Hard_Drive_Capacity: 3 terabyte
Corel programs: PSP X 9 64bit PSP 2018 Ult 64bit
Post by mckinnell »
Hi to all,
This from Corel re the ongoing problem fix e mailed to me to day, and, it works bang on:-
JV Pascual (Corel)
Feb 25, 22:59 EST
Hello Tfm,
Thank you for contacting Corel Technical Support.
My name is JV and I have been assigned to your ticket.
I understand that the you are having issues with the program, let me go ahead and help you.
Try to update your windows programs and reset your I.E. Corel Programs are very dependent to Internet Explorer. Here's a simple step to reset your I.E.
1. Press WINDOWS KEY + R
2. Type INETCPL.CPL and hit OK (this will pull up Internet Options)
3. Go to the Security tab and hit "Reset All Zones To Default Level"
4. Go to the Advanced tab and click "Restore Advanced Settings" and do a Reset.
5. Click OK
6. Relaunch the installer and/or software.
Important: Also make sure that the browser (IE) is up to date. If IE is version 8, make sure to update it to version 10 or 11 by having the customer run WINDOWS UPDATE.
To check the version of IE, launch the browser and click HELP > ABOUT INTERNET EXPLORER.
Also, I would suggest removing "Temp Files". Click the link below and follow the instruction:
http://howto.corel.com/en/c/How_to_remo ... tem_issues
> Restart your computer.
Please do not hesitate to contact us with any further questions.
JV
Corel Technical Support Services
Follow the above as stated and, you will resolve your problem re script/java error google map...........
Very best regards.........................Tom......
kalidor
motherboard: Dell Inc. 083HX3 A11
processor: 2.40 gigahertz Intel Core i5-2430M
ram: 8Gb
Video Card: NVIDIA GeForce GT 525M
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 750
Monitor/Display Make & Model: Generic PnP Monitor (15.3")
Post by kalidor »
I have found that "Magix Photo Manager 16 " works ok with Google maps, but I would rather use PaintShop pro.
mckinnell wrote:Corel Programs are very dependent to Internet Explorer. Here's a simple step to reset your I.E.
5. Click OK
As an important footnote, I would add that this does NOT mean you have to use Internet Explorer. But keeping IE up to date, and resetting the Advanced Settings works to fix a number of other problems in Video Studio even when the users in those cases never used IE. I was one such user...
kalidor
ram: 8Gb
Post by kalidor »
Windows 10 microsoft own photo programme works well with GPS map.
kalidor
ram: 8Gb
Post by kalidor »
Hi mckinnell .
I had already done as you have advised, it was also recommended by Corel chat but it didn't work. But I am happy enough using Microsoft's photo programme just for gps positions although not for editing. I'm off to New Zealand for 5 weeks in a motorhome and it is always nice to have the positioning logged.
But I will keep trying to sort Paintshop pro maps script error probs.
jayson1945
processor: Intel Core i-5 3.2Ghz
ram: 4GB
Hard_Drive_Capacity: 500gb
Monitor/Display Make & Model: BenQ
Corel programs: PSP X2, X4, X7, PSP 2018,
Post by jayson1945 »
Hello all. New here - came across the forum while searching for solutions to (many) issues with PSPX7. Same issue with map mode, lock up have to kill it with task manager. I have found a work around that I thought might benefit some of you. Although the prog recommends using IExplorer I changed the default to Firefox and at least it doesn't freeze and can navigate away without closing down using task manager. Also deleting the browser IExplorer to leave it blank stops it locking up. From the User Manual:
Selecting Web browsers
Corel PaintShop Pro lets you preview your images with Web browsers.
You can add, change, or delete Web browsers.
To add Web browsers
Edit workspace
Manage workspace
1 Choose File  Preferences  File Locations.
The File Locations dialog box appears.
2 From the File types list, select Web Browsers.
3 Click Add.
The Browser Information dialog box appears.
4 Click Browse.
The Web Browser Path dialog box appears.
5 Navigate to the folder containing the Web browser executable file
(with the filename extension .exe), and click Open.
6 Click OK.
To change Web browsers
Edit workspace
Manage workspace
3 Select a browser from the list.
4 Click Edit.Customizing Corel PaintShop Pro 699
5 Click Browse.
6 Navigate to the folder containing the Web browser executable file
7 Click OK.
To delete Web browsers
Edit workspace
Manage workspace
4 Click Delete to remove the browser from the list.
5 Click OK
jayson1945
ram: 4GB
Further to my first post it appears I'm wrong as trying the map mode just now brings up the all too familiar problem whatever browser I link PSP to. Sorry everyone :(
kalidor
ram: 8Gb
Post by kalidor »
Thanks for trying.
crawdaddy
motherboard: Gigabyte Z27ON-WiFi
processor: Intel i7-7700
Video Card: Nvidia GeForce GT 730
Hard_Drive_Capacity: 4.5TB
Monitor/Display Make & Model: Viewsonic
Corel programs: Corel PSP Pro 19.2.0.7 x64
Post by crawdaddy »
Just adding my own name to the customers interested in resolving this infuriating problem.
My own use of PSP is very elementary/minimalistic. I don't (knowingly) run any scripts etc and use it for the simplest of purposes, and this program error occurs immediately the program starts - thus making even the modest use I try to make more than problematic.
I note that like others I use Firefox as my default browser and note for the record that when this PSP error crops up there's an additional report that says
"You are using a browser that is not supported by the Google Maps Javascript API. Consider changing your browser" Unlikely as the tail should not wag the dog. (This error report is also problematic and cannot be dismissed.
If I capture the URL that triggers this (http://maps.google.com/maps/api/js?v=3. ... uage=en-US) and feed it in to Internet Explorer, it asks to be allowed to run some Javascript, but then FAILS with a "Microsoft JScript runtime error" code 800A1391. That may imply that even if I tried to get Javascript working fine in Firefox (about which I have little or no knowledge etc), then as it fails in IE it may fail anyway.
HTH
