Why do I get this 'tk' window?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
While working on my novice scripts I sometimes get this 'tk' window after an error. It usually seems to be when my script is trying to use an empty clipboard. But I don't seem able to close it without restarting PSP 8.
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Why do I get this 'tk' window?
Post by LeviFiction »
PSP8 did not have access to the ctypes library, so when we made the pasting script we had to find another way. The only way to do that was to use the TKinter library. Unfortunately, it's not the best solution we could have come up with but it was necessary to automate pasting text as a text object. It seems the library doesn't respond well to being called via RunScript.
terrypin
ram: 32 GB
Post by terrypin »
Thanks, understood. (Well, sort of!)
I've just noticed that a few of the scripts I use (made with help here, probably from you, a year or two ago) have 'from Tkinter import Tk' at their start:
Code: Select all
from JascApp import *
def ScriptProperties():
    return {
        'Author': u'Terry Pinnell',
        'Copyright': u'',
        'Description': u'',
        'Host': u'Paint Shop Pro',
        'Host Version': u'8.10'
def Do(Environment):
    # EnableOptimizedScriptUndo
    App.Do( Environment, 'EnableOptimizedScriptUndo', {
And at the end I see:
Code: Select all
def getText():
    r = Tk()
    text = r.selection_get(selection='CLIPBOARD')
    r.withdraw()
    r.update()
    r.destroy()
    return text
Cannot test right now, but could that have been added to deal with this issue?
ram: 6 GB
Code: Select all
#normal Script code here
def getText():
    r = Tk()
    r.withdraw()
    r.update()
    r.destroy()
    return text
That is literally the paste text feature we came up with. Yes, that's the reason that the Tk window pops up. When a script runs getText() PSP will attempt to grab text from the clipboard using the tkinter GUI library that comes with PSP. It will then return the text copied to whatever function is using it. If the script you're running has no need of pasting in text, the script should not have these lines.
terrypin
ram: 32 GB
Post by terrypin »
Thanks, understood. I plan to work on it again later today but I think those lines are indeed for su scripts that do indeed use text from the clipboard.
