An impossible selection?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
After an hour or so trying in vain to make the following selection, I suspect I'm attempting the impossible?
I want to select the thin yellow country border (mainly Italy/Austria) that I've captured as a JPG from Google Earth. (So that I can thicken it and change its colour.)
Here are three (downloadable) screenshots:
https://www.dropbox.com/s/1lk6pen7l9hr1 ... .jpg?raw=1
https://www.dropbox.com/s/w4784rwjgms2h ... d.jpg?dl=0
https://www.dropbox.com/s/dfbbflo6ppl6x ... 2.jpg?dl=0
EDITED a few minutes later
Aaagh - so obvious! I'll leave the post rather than delete it, in case anyone else ever makes the same mistake. Namely capturing as a JPG! After saving as a PSPimage the selection was simple. (Except, oddly, for a pixel or two in the Alps which were not the pure yellow of the rest.)
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
terrypin
ram: 32 GB
Re: An impossible selection?
Post by terrypin »
Another puzzle arose when I came to fill the expanded selection. Despite having opacity at 100 and mode at None, I had to repeatedly click until I got a solid yellow.
My screenshot illustrates this:
https://www.dropbox.com/s/qhqpv7hqkn71l ... mage?raw=1
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
You need to play with the Tolerance.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Jean-Luc wrote:You need to play with the Tolerance.
Tolerance isn't available for the modes None and All Opaque.
I seem to recall once running into the same issue but can't remember what caused it. However, while waiting for a proper response you could try this workaround. Once you have your selection completed and before filling it you could create a new transparent raster layer. With that layer active try flood filling the selection. If that works, once filled you can then merge the layers.
JoeB
Using PSP 2019 64bit
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Okay, according to the sample image it took a lot of fills to make the line look solid and full, each clicking was slightly transparent and it built up. Correct?
Looks like you might have a feather/soft-edge to your selection. Have you tried using Unfeather?
I just tried this, with 98% success (some parts didn't want to be selected but the rest went very smoothly)
My steps were:
1) Select All
2) Selections -> Modify -> Select Color Range (selected the brightest yellow on the image, tolerance of 100, softness of 20, subtract color range)
3) Selections -> Invert Selection
4) selections -> Modify -> Expand (by 3 pixels)
5) Use fill tool set to bright yellow, Match mode none, opacity 100, blend mode normal, sample merged deselected.
terrypin
ram: 32 GB
Post by terrypin »
Thanks Levi, I think that’s it. Bedtime here so will get on the case again tomorrow.
terrypin
ram: 32 GB
Post by terrypin »
I repeated the exercise first thing today and conclude that, as usual, the devil is in the detail. Before trying the suggestions from either LeviFiction or JoeB I started from scratch with this capture:
https://www.dropbox.com/s/8gluetoe06rev ... mage?raw=1
And here's a zoomed in section:
https://www.dropbox.com/s/5vua2ftcaisu0 ... mage?raw=1
from which it's clear that there are many 'near-yellow' pixels.
So (as Jean-Luc implied, although in a different context) I need to take care over tolerance when making the selection. I started with Magic Wand settings of Replace, RGB value, Tolerance=20, no Feather, no Anti-alias. (Later I aim to experiment with the impact of those. As mentioned, I think I had Feather set to 1 or 2 yesterday.) My first click selected only a short selection so I increased Tolerance to 30 and stepped my way through the remaining border. I suppose I could have increased Tolerance above 30 and achieved the full selection more quickly, but then I'd have risked straying outside.
I think that initial careful selection was the critical step. I was then able to use the Fill tool set to None, Opacity=100 and fill the border with solid yellow (or any other colour).
I then realised that, unlike yesterday, I had not yet expanded the selection by 1 or 2 pixels. So I then did so and filled the border again with one click. Here's the satisfactory result:
https://www.dropbox.com/s/h6gtwdwozmskr ... mage?raw=1
Greatly appreciate all the help, learned a lot once again!
Jean-Luc
Post by Jean-Luc »
How is the initial yellow line made ?
Could it be painted on a transparent layer above the map ? If so, it could be easier to select.
terrypin
ram: 32 GB
Post by terrypin »
Jean-Luc wrote:How is the initial yellow line made ?
As described in my opening post: captured from Google Earth.
One thing I’ll try next time is to apply one of my darker GE map overlays before the capture.
