VS 10 Screen Recorder Error #0
RobCom
- motherboard: EVGA Z590 Dark
- processor: 19 11900k
- ram: 32gb
- Video Card: EVGA RTX 3080 FTW3 Ultra
- sound_card: Creative AE-7
- Monitor/Display Make & Model: LG 4k
- Corel programs: Roxio NXT8 Pro, PSP2021 Ultimate, WinDVD
Hey y'all, I'm new to VS10 and am trying to get to know the app, I tried to record a desktop video for a sample to play around with and got an error, "Prepare Record Failed!!! #0" when the countdown starts.
IF I uncheck "system audio" in the audio settings it will record but I don't get any system sounds.
any ideas on where to go from here??
thanks
EVGA Z270 Classified K ; i7 7700k ; 16gig Corsair Vengeance DDR4 3200 ; EVGA 1080GTX SC ACX ; Creative Zx
thanks
Re: VS 10 Screen Recorder Error #0
Hi Rob
And welcome to the forums
I do not know, Screen Capture works for most Unfortunately when it faulty it’s a bit of a pain to fix.
Can you try deselecting System Audio, then try Sound Check, Input options, is there other options than Mic?
Is your system Audio being used by another app?
Have you tried re-installing the audio drivers.
Sorry i do not have a definite solution
RobCom
- ram: 32gb
Hey Lata thanks for the reply,
I just recently reinstalled my sound drivers and updated them to the latest because of the last Win 10 Creators update, I also reinstalled the DirectX installer just to make sure.
I have one Creatives Zx series PCIe cards, it should be able to handle being used by several apps at once with no problems but, no I was not running anything else at the time that was using sound. (it's this one: https://www.newegg.com/Product/Product. ... 6829102049 )
I did run a sound check and my mic works fine and I CAN record a video with voice over enabled only, but if I enable "system audio" it crashes every time with the error "Prepare Record Failed!!! #0".
I do already have a screen recorder form Cyberlink and it works fine, I just wanted to try out the one with VideoStudio 10 to see which one worked better.
Thanks for trying to help out, I do appreciate the effort,
Have a fantastic day!!
Hi Rob
I search the forum and found this post, bit of a long shot
http://forum.corel.com/EN/viewtopic.php ... 43#p312543
RobCom
- ram: 32gb
Ok I just made a discovery, the Cyberlink screen recorder allows me to choose from wmv OR mp4 for recording format, the Corel one only gives me the wmv option.
If I set the CL recorder to wmv format the video will record but has an error saving the video, BUT set in mp4 format it records and saves the video properly, although there is an annoying echo in the voice recording.
If I set the Corel recorder sound options to record voice ONLY it records fine, saves the video, and gives a very nice voice recording. ONLY enabling system audio causes the crash.
It must have to do with the wmv format and windows 10, I seem to remember back when win 10 first came out it had many issues with some codecs, I don't remember specifically but I remember using the OBS open source recorder for a project and having issues with playback of recorded sound, I had to use install VLC media player and use it to hear any sound as none of the windows apps would play the recordings properly.
I notice that I can ONLY choose wmv in the recorder, is this correct? or should I have other options?
Also I cannot choose to "capture to library", it is grayed out.
Is it possible that it is not installed correctly?
thanks for any info/input
RobCom
- ram: 32gb
lata wrote:Hi Rob
And THAT solved it!
I had to change the system playback settings back to stereo and it works!!
I like the sound capture of the Corel recorder much better then the one form CL, I'll just have to remember to change it when doing recordings and then switch it back when watching my TV or movies.
thank you VERY much for taking the time to help me out, I almost wore out the Bing search engine trying to solve this one...lol
Records to Wmv only but should record to library, run Video Studio and launch Screen Capture from the Record / Capture options, Spool Icon below preview screen.
I asked earlier.
If you choose Voice - Sound Check – Input Device, is there an option for Stereo Mix?
I am not having any problems with the Screen Capture, although that does not help you other to confirm it does work.
Missed your earlier post, good its working
there is another issue regarding Surround Sound and Voice recordings, project properties have to be Stereo
I asked earlier.
RobCom
- ram: 32gb
Ok that solved the library issue, it does work if I launch from within VS10, thanks you again!lata wrote:Hi
When I select Voice - Sound Check – Input Device, I get: Digital In, Microphone, What you hear, and that's it. No option for stereo mix that I can see.
MrJohnny
- motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
- processor: 3.00 gigahertz Intel Core i7-5960X
- ram: 32GB
- Video Card: NVIDIA GeForce GTX 960
- sound_card: onboard
- Hard_Drive_Capacity: 8TB
- Monitor/Display Make & Model: ASUS VH226
- Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Windows 10 does not show Stereo Mix if it is disabled. The link below gives a good indication how vto activate/access.
https://www.youtube.com/watch?v=Bd3moKLV5sE
John
John
RobCom
- ram: 32gb
Interesting MrJohnny, I already have show disabled devices turned on but I don't have Stereo Mix.
I wonder if installing that Realtek driver/codec will interfere with my Creative SoundBlaster Zx?
MrJohnny
- ram: 32GB
Don't know!!!!!!!!!!!!!!!
Be careful, ensure a fallback position if you do try it and it goes wrong.
Sorry cannot be more helpful.
John
John
It may be the type of Audio driver that names the Stereo mix as Digital in
I would not worry or change things as you now have Screen Capture working
RobCom
- ram: 32gb
Yeah you're probably right, it's working with just a little adjustment, so I'll just use it as is.
thanks everyone for your input
