pictureshow version 4.0
scpenner
Post by scpenner »
Hi....I purchased version 3.0 about 5 days ago..and having problems burning DVD's..and then when it does finally burn...TV has flickering on some of the pics.
Has anyone purchased version 4.0 and how is it working??
jeffreymeis
CD/DVD PictureShow 4
Post by jeffreymeis »
:x PictureShow4 is awful. I can't even use it. I've loaded my pictures, but when trying to add music it locks up "error" I have to close it up. When I try to reopen it I receive a msg stating "unable to open because another user is using it" I have to shut down my computer and start all over. Anyone else having this problem of "another user"
scpenner
picture show 4.0 not working
Post by scpenner »
Hi.... Picture Show 4.0 is not allowing me to burn a SVCD...or a DVD with any success.....when burning to the CD....I get a "failure to burn" message.
With Picture Show 3.0 I was able to burn a SVDC...but now I can't even do that.
Very frustrating.....any ideas???
scpenner
problem solved
Post by scpenner »
Hello.....just a follow up to my previous posts. I have burned the DVD to a folder on my hard drive...then I used NERO to burn the presentation to a DVD. worked perfectly...very happy with program and results...however, would have been nice to be able to burn directly from the program onto a DVD.
chrismead
Post by chrismead »
How did you burn to a hard drive folder - I dont get the option.
Chris
mt si guy
Burn to drive
Post by mt si guy »
both 3.0 and 4.0 let you record to a disk file.
When you get to the Burn (step 3), there's an option button to the right. It's a down-facing chevron. Click that to get the option to burn to a disk file, and to save your project file. (The Option button at the bottom left lets you change your copyright information, your author name, and so on.)
Click the Record to disk file, select a location and a file name, and you're all set.
nikwashere
v4 issues
Post by nikwashere »
Yer, im having issues too...its burns the dvd fine...picture are fine BUT no sound....GRRRR!
baustin
Burning Issue
Post by baustin »
I have just recently upgraded to Picture Show 4 and was having
the same problem burning to a disk and also to the hard drive.
Yesterday I contacted support and have received a reply with
very simple insructions that fixed my problem.
:D
dgoodaker
solution to burning problem
Post by dgoodaker »
baustin,
I have not been able to get tech support to answer my emails. What was the simple instructions that fixed the problem? I need to know asap.
jpculver
Re: Burning Issue
Post by jpculver »
baustin wrote:I have just recently upgraded to Picture Show 4 and was having
:D
Hello baustin, so what was the very simple fix? My issue is just what HD files are created that need to be burned at a later time?
