Can't use the "New" or "Template" dialogues
JoeyCanuck
Post by JoeyCanuck »
Hi.
(I purchased the orginal Jasc shareware version somewhere around 1996 and I've been using PSP 9 until just recently)
I purchased the PSP ultimate package yesterday and I'm having a strange problem. I can open files and manipulate them, but I can't use the "New..." or the "Template..." buttons without PSP crashing. I can't use "new" from the file menu, either.
I always get two indentical instances of the error message dialogue "Corel Paint Shop Pro (x64) has stopped working"....one about two seconds after I press "close program" on the first error message.
Event Viewer records three errors each time
1- a .NET Runtime error....
Application: Corel PaintShop Pro.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: ***.InteropServices.COMException.......
2 - Two identical Application Errors that show at the same time
Faulting application name: Corel PaintShop Pro.exe, version: 20.0.0.2, time stamp: 0x59ce3586
Faulting module name: KERNELBASE.dll, version: 10.0.16299.15, time stamp: 0x4736733c
Exception code: 0xe0434352....
I've tried
- Windows Update repair tool
- Clearing all Windows and Internet caches
- Clearing Corel caches
- .Net Framework repair tool
I haven't reinstalled the package yet...hoping for suggestions.
Joe in Calgary
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: Can't use the "New" or "Template" dialogues
Post by Radim »
Here are requirements:
https://www.paintshoppro.com/en/product ... tech-specs
But you will need a *fully updated* Windows 10, Windows 8/8.1, Windows 7. 8)
Especially fully updated IE & .Net Framework.
EDIT: I don't know why programmers at Corel still depends on IE core that is very slow to start. It is used too much in PSP and takes performance down.. :|
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
JoeyCanuck wrote:Faulting application name: Corel PaintShop Pro.exe, version: 20.0.0.2, time stamp: 0x59ce3586
Did you just mis-type the version number in the line I quoted? The latest PSP 2018 update should update PSP to version 20.2.0.1. Before that update the "New" file open did, I believe, create issues. You can get the update patch from Corel's site here:
https://www.paintshoppro.com/en/support/updates/
JoeB
Using PSP 2019 64bit
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Have you tried resetting PSP to default by holding down the Shift key as you start the program by double clicking the desktop icon
JoeyCanuck
Um, no I don't think so. ;] I used the update tool you provided and it responded that I was up to date. I just purchased it the other day.
Was it you who suggested the shift/click new button solution in another thread? If I hold down shift while clicking "new" it'll create a new file, but it doesn't work if I shift/click "template"....I'll get the same error then.
JoeyCanuck
hartpaul wrote:Have you tried resetting PSP to default by holding down the Shift key as you start the program by double clicking the desktop icon
Yes, thanks for the tip. Unfortunately it had no effect.
JoeB
ram: 8 GB
Post by JoeB »
You should re-check the version number of your PSP by going to Help>About in the menu. The version number will be on the screen that opens. There is something wrong if the version number you see is as you posted it and not as I posted it.
JoeB
JoeyCanuck
Actually, you just kind of dropped into the thread JoeB. Since I purchased within the last week, why shouldn't it be 20.2.0.2?
[edit] Whoops...I spoke too soon. Let me check that.
JoeyCanuck
That's what it says in event viewer: Faulting application name: Corel PaintShop Pro.exe, version: 20.0.0.2,
Under "About" in the program, it's 20.2.0.1
What is the significance of this?
JoeB
ram: 8 GB
Post by JoeB »
JoeyCanuck wrote:That's what it says in event viewer: Faulting application name: Corel PaintShop Pro.exe, version: 20.0.0.2,
I don't know what the significance of that discrepancy is, I'm afraid. But at least "About" shows that you do, in fact, have the correct version. Somebody else might be able to explain why the event viewer indicates a different version number and whether or not that is actually significant. It may not be.
JoeB
