Try to make a script recording with the Topaz Labs Adjust plugin in Painshop Pro 2018.
This is what I do:
- Open a image
- Push the red recording button
- Duplicate a layer and name it Topaz Adjust
- Go to effects open Topaz Adjust
- Apply the desired effect
- Click OK the plugin closes and the effect appears on the layer
- Go to file> save as and save as a jpg
- Stop the recording and name the preset
- Load a new image
- Run the effect
Code: Select all
Executing RunScript
Executing EnableOptimizedScriptUndo
Executing LayerDuplicate
Executing Layer Properties
Executing Topaz Labs_Topaz Adjust 5
Executing FileSaveAs
------- Command Execution Failed -----------
Command Name: FileSaveAs
Error Text: This script has attempted an operation that is not permitted in a restricted script. This script may be run by moving it to a trusted directory.
Traceback (most recent call last):
File "<string>", line 130, in Do
JascApp.Rexec Failure: Restricted script violation - this script must be trusted in order to run.
Script 'Topaz-Adjust-cold' has completed with an error.
Executing RunScript
Executing RunScript
David
