Just do what I said.
Down load the image.
Resize it.
No need to add an extra layer. That is exactly the point.
PSP 2018: Re-sizing Hi Res Image causing outline.
- flagpole
- motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
- processor: Ryzen 2600
- Video Card: RTX 2060
- sound_card: on board
- Hard_Drive_Capacity: 6.5TB
- Monitor/Display Make & Model: Iiyama 27"
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: PSP 2018: Re-sizing Hi Res Image causing outline.
I did, and edited my post accordingly.flagpole wrote:Just do what I said.
Resize it.
JoeB
Using PSP 2019 64bit
JoeB
- flagpole
Excellent.JoeB wrote:I did, and edited my post accordingly.flagpole wrote:Just do what I said.
Resize it.
When you edited your post you sort of left the start the same. Like you didn't have the issue. Like you couldn't see it.
This is only an example the reality is much more annoying, especially when you're dealing with colour.
By nonpixel resize i mean not nearest neighbour. I obviously realise that all methods of resize involve pixels.
- hartpaul
- ram: 8 Gb
Stop the Presses SweetCryssy. I don't get the halo effect if I use Pixel Resize. Can you or others that see it verify the fact.
And Flagpole that also solves your problem as well. I took your image 500 x 500 pixels and resized down to 100 pixels and then scaled up and could see the grey added pixels easily, but using Pixel Resize no problem.
- flagpole
Yeah but pixel resize is crap.hartpaul wrote:Stop the Presses SweetCryssy. I don't get the halo effect if I use Pixel Resize. Can you or others that see it verify the fact.
The problem is the logic is wrong... Whenever interpolation is required and it doesn't have an RGB value for a pixel it assumes a value of 0,0,0. This is probably a null value.
Pixel resize is also known as nearest neighbour is the most basic resize algorithm. Produces awful results.
I just use the Gimp.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Sir,flagpole wrote: You don't understand what I'm trying to explain..
I read : "I'm resizing it as I always do by pixels" in SweetCrissy's message.
So, I applied the Resize by pixel method.
When resizing by the other methods, yes, I see the grey color around the border.
JoeB
- ram: 8 GB
I've done another edit to indicate that further below my original comments there are comments about using the white background.flagpole wrote:Excellent.JoeB wrote:I did, and edited my post accordingly.flagpole wrote:Just do what I said.
Resize it.
JoeB
JoeB
- flagpole
