Dolby Audio not Project Settings option
rdenny
Post by rdenny »
UVS9: While I can get Dolby (AC3) audio when burning, etc., I don't see it listed as a Project Option. Am I missing something?
jchunter
Post by jchunter »
Bob,
This is a bug in VS9.
The workaround if you capture to Dolby sound is to ignore the problem until you create your project video file. Then, in SHARE/Create Video File, do not select "Same as Project Properties" but instead, set the audio properties to Dolby in the Custom/Options/Compression tab.
John
rdenny
Post by rdenny »
jchunter wrote:This is a bug in VS9.
OK, thanks, I suspected so. I found it in the custom compression stuff. I reported it in case ULead listens here.
-- Bob
Post by Trevor Andrew »
When you go to 'Share--Create Video' select 'Same as first Video clip'
This will use the captured clip properties.
If you havent captured to Digital Dolby:-
Go to Tools--Make Movie Manager create your own template to include Digital Dolby.
The template will be available from the 'Create Video' window.
The template will always be there, you should have no need to use 'customise' every time.
Trevor
