Problem Alpha Channel Issue
3deoskill
Corel programs: Corel
Post by 3deoskill »
Hi guys,
I am a 3D freelancer and use Paintshop Pro X9 for texture creation etc.
I have a big problem with my Alpha Channels. (Support sucks)
Example: I have a picture and for instance create a rectangle selection and save this selection into the alpha-channel....ok this is the common method.
My selction now is saved into the alpha channel. Everything is fine.
But once I save this image as *.tif , *.tga, *.png, whatever format which supports alpha-channels, and load it in Paintshop Pro X9, it shows me the Alpha-Channel transparent.
All RGB informations are lost.
The support said that Painthop can´t handle Alpha-Channels and doesn´t support them.
Ts so why do I have the option to save it into the alpha-channel, when it is allegedly not there.
Screenshot Saving Alpha:
https://drive.google.com/open?id=0B7Ovb ... W9yYjlNTzA
The common way to show the tranparency in the alpha channel is to load the alpha channel as selection and create a mask out of the selektion.
When I load this picture, which I have saved in Paintshop into Cinema 4D no problem, Cinema reconizes the RGB Picture and I can switch on/off the Alpha. Or Unity Game Engine also can handle this.
The support really said, it can´t save Alpha Channels , are they serious....?
Sorry for bad English.......
